| P_J |
 P_J Nearly there...
 Posted: 22:57 - 04 Aug 2003 Post subject: oh god, what did i do |
After d!cking about yesterday with the air box and carb etc and re-attatching some bits that honda thought to leave dangling for me (1100mile on, only just discovered), i have found that my NSR has lost its ... umff.
From Idle (about 1.5k), whip the throttle back and it kinda, just... farts at me. Before it used to react like it should, throttle back and revs would rise accordingly.
If you slowly raise the revs to about 5/6k then whip the throttle back, it does what it should, revs rise quickly.
This has dramaticaly effected the acceleration.
The screws on the right hand side of the carb (as you sit on it), one small, other little bigger with a spring on it. i have adjusted them slightly as the idle was a bit low (bout 1.2k), but this was before i took out the box etc, so this shouldnt have affected anything.
What can i do to get back the accelaration my bike used to have? Anything i took out, i put back as was. ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| McJamweasel |
 McJamweasel BCF Junkie
| P_J |
 P_J Nearly there...
| McJamweasel |
| P_J |
 P_J Nearly there...
 Posted: 23:34 - 04 Aug 2003 Post subject: |
thanks McJam, thats helpful.
Read in the manual, how to adjust idle. Followed the instructions, that fixed the idle problem.
The other problems occurred when i took out the air box to get to the jubilee clip that wasn't attached to the carb+hose to engine. like i said, put everything back, as was.
I would appreciate ideas on how to fix it, if anyone has ideas or the know how, rather than people re-iterating what i already know (if it ain't broke, don't bugger about with it). ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| P_J |
 P_J Nearly there...
| Scotty |
 Scotty Scooter Boi
| P_J |
 P_J Nearly there...
| Scotty |
 Scotty Scooter Boi
| P_J |
 P_J Nearly there...
 Posted: 23:51 - 04 Aug 2003 Post subject: |
I flogged it up and down the bypass and tried to fiddle while i was out on the road.
Actually pulled the choke out while was idling and it chugged and stalled. Starts first click though, but that could just be because it was warm. ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| TGE125NSR |
 TGE125NSR Banned
 Posted: 00:04 - 05 Aug 2003 Post subject: lol |
You have messed with the pilot air screw.screw it all the way in and out 1.5 turns
If it isn't broke, then don't fix it!  |
| P_J |
 P_J Nearly there...
 Posted: 00:14 - 05 Aug 2003 Post subject: Re: lol |
| TGE125NSR wrote: | You have messed with the pilot air screw.screw it all the way in and out 1.5 turns
Maybe sound like a dumb question, but not if you don't know.
Which is the pilot air screw (yes, i really know nothing about my bike). But if you don't ask... you will never know, you also don't get ridiculed as much
I did though, after a comment from Scotty, go out with a mag light and check i had done up the jubilee clips. I hadn't (Yes, i'm tit).
I had definitely up the second one because i remember cursing the dealer, but i hadn't done the one from the airbox to the carb after i re-fitted it, the one that was fine in the first place.
Which is the pilot screw? What effect does it have on what. don't laugh, i'm learning!!!  ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| Kickstart |
 Kickstart The Oracle
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| P_J |
 P_J Nearly there...
 Posted: 21:47 - 06 Aug 2003 Post subject: |
| P_J |
 P_J Nearly there...
 Posted: 21:50 - 06 Aug 2003 Post subject: |
oh, by the way, i fixed it! ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| Lee |
 Lee Trackday Trickster
| cagiva gezzer |
The last post was made 23 years, 59 days ago. Instead of replying here, would creating a new thread be more useful? |
