Clutchless Upshift
veeeffarr
PostPosted: 21:20 - 08 Jan 2007    Post subject: Clutchless Upshift Reply with quote
Just been out practising my clutchless upshift on my GS500e after reading some threads in work at lunch.
Have found that when I get to about 8,500rpm if I back off a TINY amount on the throttle (say about 1/2mm) I can just nudge up the box without any force whatsoever.
Am I doing things right? (Ignoring the embarassing kangaroos a few times).
Seems worth doing, as it's fast as fuck clutchless.
Whosthedaddy
PostPosted: 21:22 - 08 Jan 2007    Post subject: Re: Clutchless Upshift Reply with quote
Then you would have read the fors and againsts in them too Wink
For the record, I only ever did it out of laziness or forgetfulness Laughing
Quote Me Happy
PostPosted: 21:26 - 08 Jan 2007    Post subject: Reply with quote
Sounds about right. Back off the throttle a bit more to ease up on the kangarooing Thumbs Up
Zimbo
PostPosted: 21:28 - 08 Jan 2007    Post subject: Reply with quote
Yes you're doing it just right I'd say Smile
veeeffarr
PostPosted: 21:46 - 08 Jan 2007    Post subject: Reply with quote
I find if I back off too much then it won't go up the box at all, hence the kangaroos Razz
If the gear just slots straight in with no force I can't see a down point to it to be honest... It's a £700 bike anyway and if it goes bang then it gives me that bit more justification to walk into the dealers with my £2500 finance limit and get something I really want Twisted Evil
edd
PostPosted: 13:42 - 09 Jan 2007    Post subject: Reply with quote
If you slightly weight the pedal with your foot before backing off the throttle it will drop in without you having to time anything. Then just throttle on again as soon as it moves.
Bluespark Automotive - Diesel Tuning for Performance and Economy
feef
Energiser Bunny
PostPosted: 13:44 - 09 Jan 2007    Post subject: Reply with quote
if you slightly weight the shifter before backing off then you risk wearing the gears and selector forks over time.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
edd
PostPosted: 13:52 - 09 Jan 2007    Post subject: Reply with quote
Yeah im aware of the "club footedness" problem causing selector forks to bend. Im not talking about using much force at all here, or any length of time, just enough that you can feel the box with your foot go from heavy to light as you back off. This method might wear selector forks over time. I've never had a problem with it as yet but Ive not really had one bike in one peice on the road long enough to notice.
Finglonga
PostPosted: 14:21 - 09 Jan 2007    Post subject: Re: Clutchless Upshift Reply with quote
Been doing it for years, hardly ever use the clutch for up changes....Smoother without. Never needed a new clutch or gearbox yet.
As long as its done right there will be no damage. Downshifts are a different matter, easy once you know how but practice on someone elses bike. Wink
Andy Sez....
F.Y.Y.F.F.
ncrn
PostPosted: 16:33 - 09 Jan 2007    Post subject: Reply with quote
I've found that as long as your revs are increasing, you can upchange no problem what so ever, so I just give it a little extra throttle then kick up and it goes straight in every time. Im not sure if this is similar for a bigger bike I am only on 2T 125.
Cog Head
PostPosted: 17:04 - 09 Jan 2007    Post subject: Reply with quote
i found out by accident when i first got my mito was bladdering it down the duel carrige way and went to change up just before the redline and missed the clutch. it was great, there was a sudden power surge where theye usually isnt one, i was kinda shocked, but got HUUUUUGE grin factor off it, dont do it too often tho cus i can imagine everything in the gear box is being bashed about
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
Finglonga
PostPosted: 17:51 - 09 Jan 2007    Post subject: Reply with quote
Er....thats the wrong way around, you need to decrease the revs slightly to change "up" a gear then back on the power, doesn't matter what bike your on?!?!https://img.photobucket.com/albums/v112/finglonga/Finglonga%20Inc/ne_nau.gif
Andy Sez....
F.Y.Y.F.F.
McGee
O RLY?
PostPosted: 19:25 - 09 Jan 2007    Post subject: Reply with quote
I love doing it as it sounds amazing.
You just get a constant almost GTA style engine noise.
Its pronounced Jixxer!
befdelta7
PostPosted: 19:32 - 09 Jan 2007    Post subject: Reply with quote
have never done it tbh, dont want to cause any damage to my bike as its a j-reg 1992 and knowing my luck it would go boom!
might try it sometime next week when im back on the road (insurance reason ... or rather lack of insurance Wink )
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
Davo
Davo To The Rescue!
PostPosted: 19:39 - 09 Jan 2007    Post subject: Reply with quote
I do it all the time on my road bikes although on the CB-1 did get into a bad habit of using the rev limiter to allow me to clutchless upshift
ncrn
PostPosted: 00:10 - 10 Jan 2007    Post subject: Reply with quote
ok thats confusing, when my revs are dropping and i try to clutchless up shift, the gear lever wont budge up, it will let me drop down a gear, but it wont let me go up a gear as the engine is slowing
If i use the clutch this isnt an issue,
unless you mean after I change up a gear the revs drop?
veeeffarr
PostPosted: 00:17 - 10 Jan 2007    Post subject: Reply with quote
Ok my bike makes peak power at 8,000rpm (From the Dynograph)
I've perfected my technique so it only takes me about 1/4 of a second to change gear, if that... my revs drop by about 1,000 in each gear, so should I change at about 9,000?
Cheers,
T
alone
PostPosted: 03:19 - 10 Jan 2007    Post subject: Reply with quote
Toby - I'd assume that's your best bet.
My bike really kicks into life at 10,500rpm and redlines at 12,500rpm... So when out enjoying myself I tend to ride the bike right in the 'zone'. The only problem is I don't have much play left in the gear, instead it's just very responsive- Which is alright if you know the road and can clearly see ahead.
This reminds me, I really need to ask someone about getting my bike set up a bit better!
Bikes; '06 Triumph Sprint ST 1050 (for sale) - '95 BMW R1100GS
johnsilva
PostPosted: 13:11 - 10 Jan 2007    Post subject: Reply with quote
I ride 20,000 miles a year mainly in town, and i very rarely use the clutch to change up, and sometimes i dont use it go change down either, but timing has to be spot on with that!
Clutchless changes are fine, and are no more likely to damage your gearbox than if you did use the clutch.
HOWEVER
Timing is critical!
The risk of bad timing is higher with out the cluctch.D'oh!
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
Finglonga
PostPosted: 13:31 - 10 Jan 2007    Post subject: Reply with quote
The ideal time to change as to not give your gearbox grief is as you ease off momenterally then go back on the power. You wont be able to change when the revs are dropping as the box is still loaded with the weight of the engine. You know you have it right as the gear will just "snick" in with no clunk/jerk. Wink
Andy Sez....
F.Y.Y.F.F.
ncrn
PostPosted: 16:27 - 10 Jan 2007    Post subject: Reply with quote
So basically shut the throttle, kick the gear lever, then go back on power, I think,
Thanks by the way ^^
Finglonga
PostPosted: 16:32 - 10 Jan 2007    Post subject: Reply with quote
Not shut the throttle as such, just ease off enough to release the load on the gearbox and get engine and gearbox to the same speed for the new selected gear. Ease off too much and it will still clunk into place as the engine will be spinning too slow.
HTH.
Andy Sez....
F.Y.Y.F.F.
JonB
Afraid of Mileage
PostPosted: 16:39 - 10 Jan 2007    Post subject: Reply with quote
I rarely clutchlessly shift cause i've got into the habit of using the clutch. Oh well.
Finglonga
PostPosted: 17:27 - 10 Jan 2007    Post subject: Reply with quote
LukeVFR wrote:
I only use clutch going from 1st to 2nd, and 2nd to 1st, because it likes falling into neutral on the VFR.
I love clutchless shifting.
Very Happy
Just as well being as your clutch is shagged. Wink Mr. Green
Andy Sez....
F.Y.Y.F.F.
PostPosted: 18:06 - 10 Jan 2007    Post subject: Reply with quote
CLutchless shifting depends a lot on the bike - some bike gearboxes lend themselves to it and others dont. My gixxer 600 will clutchless-shift either way with ease, though I only do it shifting up. My 'busa on the other hand needs a much heavier foot to shift gear, and clutchless shifts can be a bit of a chore and result in missed gears. I put this down to the immensely strong gearbox - the gear are quite heavy and have much more intertis than the gixxer box so changes are slower.
The last post was made 19 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 135.74 Kb
