does anyone know how much a carb would cost?
dransy
PostPosted: 21:07 - 08 Jan 2007    Post subject: does anyone know how much a carb would cost? Reply with quote
My jets are rounded of in my carb. Thus meaning it must be the problem to all my problems.
Only carbs on ebay are 34mm but i need 28
Does anyone know how much a garage would charge for a 28mm carb for my rs125?
Cheers marc
mr.z
PostPosted: 21:11 - 08 Jan 2007    Post subject: Reply with quote
I'd suggest trying a breakers, there must be LOADS of crashed rs125's it will save you a world of hassle.. i doubt a carb would be the happy side of £100 or some other stupid bs price from new.
PostPosted: 21:54 - 08 Jan 2007    Post subject: Reply with quote
Surprised there are none on Ebay. Think they are not that expensive new (although last time I asked was ages ago, at the time £60 for a PHBH28 and £150 for a VHSB34).
Jets are cheap though compared to a new carb, and not sure what you mean by "rounded". Short of people shoving things through the middle of the jets they are not often damaged.
veeeffarr
PostPosted: 21:56 - 08 Jan 2007    Post subject: Reply with quote
Do you think he means he's done the threads in?
PostPosted: 22:13 - 08 Jan 2007    Post subject: Reply with quote
Possible. But normally a pretty coarse thread so not that easy to chew up.
dransy
PostPosted: 07:44 - 09 Jan 2007    Post subject: Reply with quote
No i mean , i was unscrewing them out , they are flat head and its rounded all the top off so i cant unscrew them out as there nothing for a screw driver to go in, if that makes sense.
So this means all the pieces from the head of the jets will be inside the jets.
I was thinking about buying new jets but then how could i get the old ones out without damaging my carb.
There 2 that are fooked are the ones really inside the carb
PostPosted: 09:50 - 09 Jan 2007    Post subject: Reply with quote
Suspect you cannot safely get them out. Small engineering shop (most towns seem to have one who does minor car and bike engineering work) could probably do it.
PostPosted: 11:51 - 09 Jan 2007    Post subject: Reply with quote
Buy the 34mm carb and fit a polini big bore kit Thumbs Up .
dransy
PostPosted: 19:49 - 09 Jan 2007    Post subject: Reply with quote
Big_HamPosted: 10:51 - 09 Jan 2007 Post subject:
nah
Rang bike gaage they quoted me £206 !!! so i certainly think i shall keep my eye on ebay
cagiva gezzer
PostPosted: 21:20 - 09 Jan 2007    Post subject: Reply with quote
https://cgi.ebay.co.uk/aprilia-rs125-rs-125-carburettor_W0QQitemZ130066958050QQihZ003QQcategoryZ78417QQrdZ1QQcmdZViewItem?hash=item130066958050
AFAIK aslong as you get a PHBH28 body you can swap the jets as needed. www.dellorto.co.uk
befdelta7
PostPosted: 22:00 - 09 Jan 2007    Post subject: Reply with quote
28mm carb
https://cgi.ebay.co.uk/CAGIVA-MITO-Carburettor-Carb_W0QQitemZ130065363524QQihZ003QQcategoryZ108841QQssPageNameZWDVWQQrdZ1QQcmdZViewItem?hash=item130065363524
28mm carb
https://cgi.ebay.co.uk/CAGIVA-MITO-MITO-125-94-CARB-CARBURETTOR_W0QQitemZ150071749131QQihZ005QQcategoryZ108841QQssPageNameZWDVWQQrdZ1QQcmdZViewItem?hash=item150071749131
or even a cheap 34mm carb (my cagiva supercity 125 is runing on a 34mm carb)
34mm carb
https://cgi.ebay.co.uk/Cagiva-Mito-EVO-125-carb_W0QQitemZ220069311536QQihZ012QQcategoryZ108841QQssPageNameZWDVWQQrdZ1QQcmdZViewItem?hash=item220069311536
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
PostPosted: 00:59 - 10 Jan 2007    Post subject: Reply with quote
There are quite a few versions of the PHBH28 carb, so try and make sure you get the right one. Also the Mito has the oil pump on the opposite side, as does the NSR125 (and the NSR oil pump pipe connects somewhere wierd from memory).
The last post was made 19 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 77.84 Kb
