Dang-tyre help
Wingchunal
PostPosted: 17:21 - 12 Jan 2003    Post subject: Dang-tyre help Reply with quote
While doing my chain a bit ago ive found 2 nails in my rear tyre Sad got some pics not good quality but what you think i should do about them!
I cant be doing with buying new tyre's i wanna sell the biatch soon.
Viper
Get off my bloody bike!
PostPosted: 17:23 - 12 Jan 2003    Post subject: Reply with quote
A bike tyre repair place will probably fix them up for about £10
...yellow pages!! Wink
https://213.86.53.185/images/smilies/tomato.gifVx
Scotty
Scooter Boi
PostPosted: 17:47 - 12 Jan 2003    Post subject: Reply with quote
Wow least your tyres have tread....
Regards
Scott
Wingchunal
PostPosted: 17:52 - 12 Jan 2003    Post subject: Reply with quote
This weather is doing my nut in, i want the days when u can just lean all over the place to come back! How many months away now ???/hmmmmmm
Doddmaster
PostPosted: 19:49 - 12 Jan 2003    Post subject: Reply with quote
In early March we should see sun Smile (the warm kind, not the cold sun that blinds you in the winter)
retrofly
PostPosted: 20:02 - 12 Jan 2003    Post subject: Reply with quote
hi
u can get them pluged because they are in the middle of the tyer, should cost between 20-30 quid
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
Phoenix
Twisted Firestarter
PostPosted: 20:32 - 12 Jan 2003    Post subject: Reply with quote
£10-15 cost you to get it repaired.
ReBorne
PostPosted: 22:28 - 12 Jan 2003    Post subject: Reply with quote
Has anyone tried that green gunky stuff you can get injected into your tyres so this sort of thing doesn't matter? I think that's about £20 too, innit? And it means you won't need to cough up next time it happens....
.......and this bit goes......erm...........
bikes4life
PostPosted: 22:33 - 12 Jan 2003    Post subject: Reply with quote
Ive heard of that stuff, i live in Dublin and i wanted to get it about a year ago and i was told it was just made illegal, but it could be different over there
PostPosted: 22:39 - 12 Jan 2003    Post subject: Reply with quote
'Slime' is one of the brands, I've had it in my (inntertubed) mountain bike tyres. I wouldn't really want it in a motorbike, it'll make your next tyre change a bit dodgy (that'll probably just annoy the mechanic doing it), I doubt it's rated to repair punctures and still be used at high speed so you'll still need to get it repaired properly, but it may make the repair more difficult.
PostPosted: 23:04 - 12 Jan 2003    Post subject: Reply with quote
Works well in mtbs. I wouldnt trust it on motorbikes.
How good are tyre repairs out of interest? They cant be as good as a normal tyre, but can you push them and abuse them as per normal rubber? Question
Scooby
Scrappy Doo
PostPosted: 01:32 - 13 Jan 2003    Post subject: Reply with quote
My bro had slime in his BMX tyres, I skidded round a corner and the tyre popped and slime squirted all over the place, imagine if that happened on a motorbike if your front wheel skidded or something...Confused
McJamweasel
BCF Junkie
PostPosted: 03:43 - 13 Jan 2003    Post subject: Reply with quote
The slime type things are only supposed to be a temp thing to get you to a proper repair. They do work tho.
As for tyre repairs, they do work and are supposd to be as good as normal tyres. The tyre manfs dont recommend them tho.
Scotty
Scooter Boi
PostPosted: 10:14 - 13 Jan 2003    Post subject: Reply with quote
They wouldnt, there losing money by you just going out and getting your old one repaired instead of buying a brand new tyre of theirs...
Regards
Scott
Ropehead
PostPosted: 11:08 - 13 Jan 2003    Post subject: Reply with quote
id put an inertube in it £12
Demonic69
The Pink Rhino
PostPosted: 11:17 - 13 Jan 2003    Post subject: Reply with quote
Slime is tested on motorbikes, up to some high-speed too and is meant to be a permanent fix.
But all the places i've asked says it really messes up tyre changes.
Back on a Blade. Just feels so right.
kev
I Hump Things
PostPosted: 11:52 - 13 Jan 2003    Post subject: Reply with quote
you can get the equivelant for motorbikes and its tested up to 200mph as far as the reapir goes it will cost you about a tenner per hole to get fixd so you best bet would to pull the nails out and stick a tube in
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Guest
PostPosted: 14:02 - 13 Jan 2003    Post subject: Reply with quote
Be very careful about putting a tube in a tubeless tyre. The inside of a tubeless tyre is not finished smoothly and will damage the tube. Special tubes are available so if you want to try this bodge make sure you get one of them
Robson
PostPosted: 14:29 - 13 Jan 2003    Post subject: Reply with quote
Theres stuff called Ultra seal tested to 165mph the seal is permenant for the life of the tire, i use it in my minimoto i was advised against this as it may offset the balance of the wheel i have had no probs at all and have no problems with the way the bike handles after using it.......i cant even notice the difference
Paul (Robson)
Demonic69
The Pink Rhino
PostPosted: 14:44 - 13 Jan 2003    Post subject: Reply with quote
Would it affect a big bike more though?
Robson
PostPosted: 15:11 - 13 Jan 2003    Post subject: Reply with quote
i imagine the principal would be the same the advert for that last stuff that ultra seal said "does not affect your machines handling" but thats somthing trying to sell it the guy who told me about it offsetting the balance of you wheels and hes a slever although i can see exactly what hes saying but at the time he told me he was trying to get me to order a new tyre for the minimoto so i'd say his opinion would be a toch baised........ive never noticed the diff in the minimoto and i lashed loads in the back tyre and they are properly scaled down bikes so for the size of them it should make the same diff as it would in a big bike as ratio of size is identicle (virtually)
Paul (Robson)
There is a gap of 204 days between these two posts...
Major_Grooves
The Doctor
PostPosted: 14:27 - 06 Aug 2003    Post subject: Reply with quote
Sorry to dig up an old post but...
... I've just noticed a nail in my tyre. It is kind of inserted sideways so that one entry/exit point is in the middle of the tyre and the other is at the edge of the tyre. The nail looks as if it has not entered the tyre deeper than the tread at any point so i am assuming it is embedded in solid rubber and doesn't enter the inside of the tyre.
Hope that makes sense. Should I just pull it out, leave it, or get it checked?
About me|@Major_Grooves|My company|Digg|Flickr
PostPosted: 14:32 - 06 Aug 2003    Post subject: Reply with quote
If its not gone deeper than tread then it should be alright. I'd probably just pull it out and see what happens, but I reckon you should probably get it checked Confused
Dr Nick
PostPosted: 16:07 - 06 Aug 2003    Post subject: Reply with quote
Tyre-Weld?.
Its says on the can " Not for use with Motorcycle Tyres", and anyway its temporary, i used it on my ped once to get me to the garage, when its in they said you can't fix the tyre now, you'll have to buy a new one.
is that it
Deano
PostPosted: 16:08 - 06 Aug 2003    Post subject: Reply with quote
were has WingChunal been lately????????????????????????????????
Dean Stone #777
EMRA 2012 final standings, Formula 600s 3rd, Superstock 600s 3rd.
www.triplesevenracing.co.uk: www.ljmotorcyclerepairs.co.uk www.gettaylored.co.uk BN RaceScience, Now officially run out of money to carry on racing Sad
The last post was made 23 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.05 - MySQL Queries: 15 - Page Size: 123.76 Kb
