Dellorto 34mm - Mikuni 35mm carb
Cog Head
PostPosted: 11:52 - 16 Jan 2007    Post subject: Dellorto 34mm - Mikuni 35mm carb Reply with quote
dose anyone have one of there that i can buy?
im after oen for my mito
and dose anyone know how to make the cables to fit ?
cheers.
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
GearboxGeezer
PostPosted: 11:55 - 16 Jan 2007    Post subject: Reply with quote
Ill sell my 34mm for £80.
What do you mean by cables fit? The throttle cable?
satans_BIG_helper
PostPosted: 16:35 - 16 Jan 2007    Post subject: Reply with quote
Will have a ratch i think i sold on all my 34mm VHSB carbs
befdelta7
PostPosted: 16:44 - 16 Jan 2007    Post subject: Reply with quote
theres a couple on ebay:
https://cgi.ebay.co.uk/aprillia-34mm-dellorto-carb_W0QQitemZ170070755530QQihZ007QQcategoryZ78417QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
https://cgi.ebay.co.uk/lambretta-vespa-34mm-dellorto-carb_W0QQitemZ330076287514QQihZ014QQcategoryZ122298QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i do not understand what you mean by 'make the cables fit' so cant help you on that one Wink
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
Marci
PostPosted: 17:36 - 16 Jan 2007    Post subject: Reply with quote
What he means is that the stock Cagiva throttle cable isn't long enough to use with the 34 and 35mm carbs - it's too short, so holds the throttle open.
Personally, I'd just go and buy a universal throttle cable and make it up meself to whatever length was required... solder on the endpieces by holding it in flame of a gas stove and applying solder just as it begins to glow red. You only need a slight increase over current throttle cable...
Flip up yer tank and you'll see a plastic circular item, into which the throttle cable from the twistgrip passes. It stops there. Out the other side come 2x separate cables - 1 for oil pump, and the other to the carb. Strip and remove this cable, then make one up that's about 3cm longer or so (check with folks on 125ccsb exactly how much extra length is needed - don't go off my guess).
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
PostPosted: 22:59 - 16 Jan 2007    Post subject: Reply with quote
Venhill should be able to help with cables.
To be honest give the effort to set them up, and having the oil feed on the other side of the carb, I would go for the Mikuni as it was a standard carb (although pretty rare).
The last post was made 19 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 49.08 Kb
