| Cog Head |
 Cog Head Could Be A Chat Bot
 Posted: 11:52 - 16 Jan 2007 Post subject: Dellorto 34mm - Mikuni 35mm carb |
dose anyone have one of there that i can buy?
im after oen for my mito
and dose anyone know how to make the cables to fit ?
cheers. ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore
McGee: Hence I smell like a gimp |
| GearboxGeezer |
 GearboxGeezer World Chat Champion
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
| befdelta7 |
 befdelta7 Brolly Dolly
 Posted: 16:44 - 16 Jan 2007 Post subject: |
| Marci |
 Marci Brolly Dolly
 Posted: 17:36 - 16 Jan 2007 Post subject: |
What he means is that the stock Cagiva throttle cable isn't long enough to use with the 34 and 35mm carbs - it's too short, so holds the throttle open.
Personally, I'd just go and buy a universal throttle cable and make it up meself to whatever length was required... solder on the endpieces by holding it in flame of a gas stove and applying solder just as it begins to glow red. You only need a slight increase over current throttle cable...
Flip up yer tank and you'll see a plastic circular item, into which the throttle cable from the twistgrip passes. It stops there. Out the other side come 2x separate cables - 1 for oil pump, and the other to the carb. Strip and remove this cable, then make one up that's about 3cm longer or so (check with folks on 125ccsb exactly how much extra length is needed - don't go off my guess). ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| Kickstart |
 Kickstart The Oracle
The last post was made 19 years, 276 days ago. Instead of replying here, would creating a new thread be more useful? |
