what tool to shrink heat-shrink?
FreshAL
Sir Crashalot
PostPosted: 15:08 - 16 Jan 2007    Post subject: what tool to shrink heat-shrink? Reply with quote
What does everyone use to shrink heat shrink?
Wall-paper heat gun, hairdryer, lighter? What works and what doesn't?
befdelta7
PostPosted: 15:24 - 16 Jan 2007    Post subject: Reply with quote
what i used(only done it 2times) is a turbo lighter, the wind proof ones that you cant see the flame. just hold it onto what you want to heat-shrink but dont hold the lighter too close to your 'work' but just enough to heat-shrink it(1cm say) otherwise hold it too close and the shrink will catch fire.
im sure theres better ways of doing it and someone will tell you how to do it correctly... best to do it correctly accually!! Very Happy
EDIT: i personally dont know how to do it correctly hence the lighter Wink
im going to keep my eye on this thread and learn how to do it properly Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
djneu-trix
PostPosted: 15:32 - 16 Jan 2007    Post subject: Re: what tool to shrink heat-shrink? Reply with quote
exactly what u said! just use anything thats hot! i use a hair dryer but it takes a while!
pg
PostPosted: 15:36 - 16 Jan 2007    Post subject: Reply with quote
Anything that's hot aye. So then putting it behind the exhaust of another bike should work....(running, obviously)
T1z3R
PostPosted: 15:41 - 16 Jan 2007    Post subject: Reply with quote
a heat gun (paint stripper) is quickest Thumbs Up
duck my sick!
Stiffler
PostPosted: 16:13 - 16 Jan 2007    Post subject: Reply with quote
I use a gas powered Soldering iron, the exaust vents from the heat catalyst works magnificently. I imagine it's similar to using a paint stripper gun. I've had some disasters when using lighters so i always avoid that now.
Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS
hmmmnz
PostPosted: 16:14 - 16 Jan 2007    Post subject: Reply with quote
lol, Mr. Green Thumbs Up a lighter if you have nothing else, but dont hold the flame in 1 place, even heat shink burns Thumbs Up
the humans are dead
I kick arse for the lord
satans_BIG_helper
PostPosted: 16:20 - 16 Jan 2007    Post subject: Reply with quote
Exactly as above or if im working away from my house without my trusty gas soldering iron... a hair drier works well but its a slow task and no where near as direct as the heat from the soldering iron Smile
JGY6000
PostPosted: 19:47 - 16 Jan 2007    Post subject: Reply with quote
i use a lighter, its the easiest method, light up run the flame along it and bob's yor uncle, no faffing about with heat guns or flame throwers Laughing
https://www.germes-online.com/direct/dbimage/50220086/Lighter.jpg
PostPosted: 22:50 - 16 Jan 2007    Post subject: Reply with quote
I use a lighter, but move it around plenty so no one area gets that hot.
PIEMON
PostPosted: 23:39 - 16 Jan 2007    Post subject: Reply with quote
HI, iff its small enough i always use the steam from ketal Cool it works for me
PIEMON
Me SPEEDING never - I was FLYING to low
ZRX61
Victor Meldrew
PostPosted: 00:05 - 17 Jan 2007    Post subject: Reply with quote
Thermite Grenade Wink
THCi
PostPosted: 00:15 - 17 Jan 2007    Post subject: Reply with quote
If you've got a bike left afterwards its a bonus!
Past: GZ 125 K4 Marauder, VL 125 LC Intruder, FZS 600 Fazer. Present: GSF 600 N K3 Bandit, GSX-R 600 X(soon)
"We're not gonna die. We can't die, Bendis. You know why? Because we are so...very...pretty. We are just too pretty for God to let us die."
jimbothe
PostPosted: 00:31 - 17 Jan 2007    Post subject: Reply with quote
I regularly use heat shrink and i have always used a butane blowtorch set on the lowest heat (yellow flame).Heat shrink does melt as said before but if you continually run the torch up and down it shrinks perfectly into place and the added heat over a heat gun makes sure it shrinks right down flush to the wires thus making them waterproof. Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Ichy
PostPosted: 00:36 - 17 Jan 2007    Post subject: Reply with quote
Soldering iron. Just run the tip along the tube. None of the problems of using a naked flame and its nice and controlled. I've used heat shrink up to 50mm diameter, to shrink that we used a kettle.
the grim reaper
PostPosted: 10:51 - 17 Jan 2007    Post subject: Reply with quote
I also use my soldering iron but I use the barrel, not the tip as it can leave residue which screws up your soldering.
Grim
Zimbo
PostPosted: 19:21 - 17 Jan 2007    Post subject: Reply with quote
Hot air gun.
Soldering irons are useful when there's nothing else around but don't heat the heatshrink evenly like a hot air gun does Smile
BFG
PostPosted: 19:43 - 17 Jan 2007    Post subject: Reply with quote
The best cheap method.
Get an ordinary adjustable lighter and use the blue part of the flame, which is much cooler than the yellow and will not burn the plastic. Turning the flame up can help as you get more blue part.
Of course, don't confuse this tip with turbo lighters, which have an all-blue flame.
Cillit-BANG
PostPosted: 22:19 - 17 Jan 2007    Post subject: Reply with quote
Zippo.
The real mans choice Very Happy
loply
PostPosted: 22:16 - 19 Jan 2007    Post subject: Reply with quote
I've always wondered why the blue part is seemingly cooler than the yellow part. From GCSE science I recall the blue flame on a bunsen burner being hotter than the yellow flame...
Yamaha SZR660 Caution to the wind, the throttle pinned!
djneu-trix
PostPosted: 22:48 - 19 Jan 2007    Post subject: Reply with quote
yer i just thought that! i think its because of the type of fuel!
but dont quote me on this as i could be very wrong Razz
cheers
pg
THCi
PostPosted: 23:32 - 19 Jan 2007    Post subject: Reply with quote
Different fuels burn with different colours. Its LPG vs Natual gas, so colouring is going to be different. Google should answer which gets which flame colour. Thumbs Up
The last post was made 19 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 115.98 Kb
