| Cruiser |
 Cruiser Renault 5 Driver
 Posted: 09:57 - 31 Dec 2006 Post subject: Bandit idle speed...? |
hey guys,
Ive got a 2001 faired Bandit 600,
Went out yesterday and noticed the engine braking had kinda dissapeared, so stopped and noticed it was idling at 2000rpm instead of 1200-1300 like normal. carried on and then stopped again, eventually it went down to 1500 then back to normal a while later. Then last nite it was on about 1100 idling, then settled down again to normal. (the bike was warm and it wasnt really cold outside)
I dont know much about bikes but maybe the choke was stuck or something?
Any help would be much appreciated,
Thanks,  |
| Pete. |
 Pete. Super Spammer
 Posted: 10:17 - 31 Dec 2006 Post subject: |
Things to check for:
Choke on slightly/stiff choke cable.
Too much free-play on the throttle cable causing cable outer to fall out of holder.
Throttle not "snapping" shut due to:
Throttle tube binding on the bar
Stiff cable due to badly routed/pinched in steering lock-stop
Not enough throttle cable free-play.
Air leak between carbs and enging (not likely and wouldn't rectify itself)
Foreign matter stuck under a butterfly (not likely) ____________________ a.k.a 'Geri'
| Cruiser |
 Posted: 10:20 - 31 Dec 2006 Post subject: |
thanks mate i`ll go an check for all of those, hopefully that`ll sort it out!!
cheers  |
| Cruiser |
 Posted: 22:37 - 17 Jan 2007 Post subject: |
sprayed WD40 on the whole cable and seems to be working fine again now, couldnt find anything wrong with it tho! cheers for the help  |
| mchaggis |
 mchaggis World Chat Champion
| Gazdaman |
 Gazdaman I did a trackday!!!
| Cruiser |
The last post was made 19 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
