Bandit idle speed...?
Cruiser
PostPosted: 09:57 - 31 Dec 2006    Post subject: Bandit idle speed...? Reply with quote
hey guys,
Ive got a 2001 faired Bandit 600,
Went out yesterday and noticed the engine braking had kinda dissapeared, so stopped and noticed it was idling at 2000rpm instead of 1200-1300 like normal. carried on and then stopped again, eventually it went down to 1500 then back to normal a while later. Then last nite it was on about 1100 idling, then settled down again to normal. (the bike was warm and it wasnt really cold outside)
I dont know much about bikes but maybe the choke was stuck or something?
Any help would be much appreciated,
Thanks, Very Happy
PostPosted: 10:17 - 31 Dec 2006    Post subject: Reply with quote
Things to check for:
Choke on slightly/stiff choke cable.
Too much free-play on the throttle cable causing cable outer to fall out of holder.
Throttle not "snapping" shut due to:
Throttle tube binding on the bar
Stiff cable due to badly routed/pinched in steering lock-stop
Not enough throttle cable free-play.
Air leak between carbs and enging (not likely and wouldn't rectify itself)
Foreign matter stuck under a butterfly (not likely)
Cruiser
PostPosted: 10:20 - 31 Dec 2006    Post subject: Reply with quote
thanks mate i`ll go an check for all of those, hopefully that`ll sort it out!!
cheers Very Happy
Cruiser
PostPosted: 22:37 - 17 Jan 2007    Post subject: Reply with quote
sprayed WD40 on the whole cable and seems to be working fine again now, couldnt find anything wrong with it tho! cheers for the help Very Happy
mchaggis
PostPosted: 00:01 - 18 Jan 2007    Post subject: Reply with quote
WD40 is a temporary fix at best. It will evaporate and/or run away. 3 in 1 penetrating oil/ Handy oil is ideal.
https://img125.imageshack.us/img125/1013/3n1oil3py.jpg
I must not be a troll...
Mmmm, Guinness
Gazdaman
I did a trackday!!!
PostPosted: 09:57 - 18 Jan 2007    Post subject: Reply with quote
I found the adjustment screwy bit on my choke cable would work loose essentially making my choke permanently half on.
Gaz
Cruiser
PostPosted: 19:10 - 18 Jan 2007    Post subject: Reply with quote
i`ll stick some of that on then, got some in the shed i think lol thanks!
The last post was made 19 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 53.6 Kb
