Positioning an Indoor Aerial
veeeffarr
PostPosted: 20:22 - 19 Jan 2007    Post subject: Positioning an Indoor Aerial Reply with quote
Right,
Bought a freeview box and a wideband aerial (An indoor one)
At the moment, it's sitting on top of my TV but when I move it it seems to randomly affect signal quality with no pattern...
Anyone know a way to get the best possible reception from an indoor aerial positioning wise?
Quote Me Happy
PostPosted: 20:23 - 19 Jan 2007    Post subject: Reply with quote
In your loft?
veeeffarr
PostPosted: 20:26 - 19 Jan 2007    Post subject: Reply with quote
Can't really, tis a shared house (rented) Sad
yambabe
PostPosted: 21:01 - 19 Jan 2007    Post subject: Reply with quote
On a windowledge upstairs that faces towards the nearest transmitter (you can google for that).
We have freeview in the bedroom, and the aerial is in the window of the bedroom on the opposite side of the house cos we could only get the BBC channels when we had it any nearer to the telly!
binge
Emo Kiddy
PostPosted: 21:04 - 19 Jan 2007    Post subject: Reply with quote
Im running similar setup to you. Ive got an areal which looks like a Mini Satelite dish. Its electricly powerd too.
I find that If I do a channel scan, I can pick up more channels depending on which way the ariel is facing.
Ive also got a perfectly clear picture, Or no picture at all. I can get about 30 decent channels, Varying depending on which way the ariel is facing each time I scan.
Do you not have a signal strength meter in the setting, so you can rotate the ariel, and it will show you how strong the signal is as you move the ariel?
<|ben|>
yambabe
PostPosted: 22:16 - 19 Jan 2007    Post subject: Reply with quote
I use a technika rabbit-ear type amplified aerial for mine, and it doesn't make much difference which way my "ears" are pointing as long as they are on the windowledge that faces the transmitter........
Sparks!
Sir Tart-a-lot
PostPosted: 22:48 - 19 Jan 2007    Post subject: Reply with quote
Look at the houses/flats/whatever around you and see which way their exterior aerials are pointing, then point yours the same way.. thats what I do for large aerials in loft or outside and never had a prob so far...
owdamer
PostPosted: 11:45 - 20 Jan 2007    Post subject: Reply with quote
I tried using an indoor ariel on my freeview box at my caravan. I found I had to move it to different positions everytime i changed channels. I cant understand why as everything is from the same transmitter.. Confused
The last post was made 19 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 55.64 Kb
