Spark Plug Covered In Oil - Bike Cuts Out
tomhunter
PostPosted: 20:22 - 20 Jan 2007    Post subject: Spark Plug Covered In Oil - Bike Cuts Out Reply with quote
Symptoms on bike
- 2t, Rieju 50cc SMX
- Starts for a little bit, but if left idling will cut out
- Before it cuts out the engine makes a different noise, runs slower me tink
- Then if you leave the bike 5 mins it will usually start again, and then cut out in a min.
Symptoms on Spark Plug
- Spark plug black with oil
What I thought
I thought maybe it floods a little or something, then cuts out.... so then drains off/drys and so works again
Here are some links to resources about oily plugs:
https://www.rmh-d.com/service/spark_plugs.php
https://www.totalmotorcycle.com/maintenance/sparkplugs.htm
Any Help Greatly Appreciated,
Alex
tomhunter
PostPosted: 21:31 - 20 Jan 2007    Post subject: Reply with quote
I think it mite be the air filter needs cleaning...
thoughts?
PostPosted: 00:07 - 21 Jan 2007    Post subject: Reply with quote
Could be air filter, sounds like its running a bit rich. Could also be that the oil pump is out of adjustment.
Try cleaning/replacing the air filter and see what happens...
hmmmnz
PostPosted: 00:08 - 21 Jan 2007    Post subject: Reply with quote
it sounds like you are running rich for one reason or another,
you may have a leaf in the air box or a clogged filter,
go for a ride and then when you stop the bike, check the plugs, see if the plug is still black,
(clean it before the ride as well) (check and clean filter before you do that)
the humans are dead
I kick arse for the lord
PostPosted: 01:36 - 21 Jan 2007    Post subject: Reply with quote
If it is actually oil, check the pump is set properly.
What sort fo 2-stroke oil are you using?
Also check you have the correct grade of sparkplug fitted (don't assume 'oh the garage fitted it so it's right', check).
If none of this or the above helps, try fitting one grade hotter sparkplug.
tomhunter
PostPosted: 02:02 - 21 Jan 2007    Post subject: Reply with quote
It is actually the wrong model of spark plug, still NGK tho and I tapped down the gap earlier today.
I'm gonna clean the filter and see if that makes a dif...
Is it standard practice to use air filter cleaning solution?
PostPosted: 02:13 - 21 Jan 2007    Post subject: Reply with quote
Well, I'd strongly suggest you fit the correct sparkplug if it is oiling up and avoid further pissing about with it until you have done so.
NGK make literally hundreds, probably thousands of different sparkplugs, you need the right one. One heat grade out makes the difference between oiling up and not oiling up, even more so on a tiny wee engine like yours.
PostPosted: 12:39 - 21 Jan 2007    Post subject: Reply with quote
Its not the right spark plug? Then there is your answer!!!
yambabe
PostPosted: 20:07 - 21 Jan 2007    Post subject: Reply with quote
My other half wants to know why are you starting it and letting it idle, why are you not starting it and riding away on it?
And if you do start it and ride away on it does it still do it?
The last post was made 19 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 61.54 Kb
