My god, what have I done??? Help needed!
EDBANGER
PostPosted: 18:20 - 21 Jan 2007    Post subject: My god, what have I done??? Help needed! Reply with quote
OK, so I changed my sprockets and chain today. An easy job, i've done it before, but this time I have somehow really made a bollox of it.
So here's my diagram to help explain my problem. I forgot to draw the clutch cable the goes into the cover just to the left of the rubber cover.
https://img.photobucket.com/albums/v693/smncttr2/public/bikeproblem.jpg
This is the cover I had to remove to get to the front sprocket. Now past experience tells me all I need to do was remove the 5 bolts, pull off the cover and we're done. This time however, after the bolts were remove the cover was loose but would now come off. I didn't want to use brute force so investigated further. I removed the rubber cover and found another bolt. I then (this is the bit where I think I fucked it up) undid that bolts. As a result the clutch cable came loose from the case. The case still didn't shift any further so I then applied the brute force. It came off, nothing broke, nothing fell out. I figure it was just all the oily, dirt that made it slightly hard to remove and I didn't need to undo that last bolt.
I changed the sprocket, reconnected the clutch cable into it's housing on the inside of the cover and put it all back together, tightening back up that screw that was under the rubber cover.
Now, the clutch seems to be perminantly on, I can change the gears, but when I put revs on, the bike doesn't move. Then after 5 minutes of head scratching I noticed oil coming from that general area, I couldn't find the exact source but there was no leak before I started.
If any of that made sense. What the hell have I done and how do I fix it?
If you can't spot the sucker in your first half hour at the table, you are the sucker.
PostPosted: 18:26 - 21 Jan 2007    Post subject: Reply with quote
That bolt (with a lock nut on it) is the clutch adjuster. From memory on the FZR600 (which uses that setup) undo it, then do it up until it just starts to make contact, back it off slightly and tighten the lock nut.
EDBANGER
PostPosted: 18:38 - 21 Jan 2007    Post subject: Reply with quote
OK, nice one Keith. Any ideas about the oil leaking??
PostPosted: 21:30 - 21 Jan 2007    Post subject: Reply with quote
Not really, nothing obvious unless it is seeping out of the clutch pushrod seal, disturbed by being under constant pressure.
Whosthedaddy
PostPosted: 21:39 - 21 Jan 2007    Post subject: Reply with quote
https://www.bikechatforums.com/files/fzr600_068_190.jpg
This was my very filthy and oily FZR engine, I take it you mean the nut behind the black rubber stopper?
I never did manage to get that damn cover off as one of the bolts was slighty rounded and would nt budge. To be honest, I thought this cover just protected the front sprocket.
https://www.bikechatforums.com/files/fzr600_073_160.jpg
Even if the metal cover was removed to change the sprocket, there appeared to be no gasket that could leak and cause the oil leak?
PostPosted: 22:03 - 21 Jan 2007    Post subject: Reply with quote
It pretty much does, but also carries the clutch actuating arm. The FZR setup is similar to the 600 Bandit, and works like a hydraulic clutch. Cable goes down to the sprocket cover, and when you pull the cable it pushes out a piece, like a piston. This pushes a bar which pokes out of the side of the gearbox casing. The bar passes through the gearbox, into the centre of the clutch and pushes directly on the pressure plate.
There isn't, but there is a seal around the clutch pushrod and around the output shaft from the gearbox. It is also pretty close to the oil drain plug.
Whosthedaddy
PostPosted: 22:05 - 21 Jan 2007    Post subject: Reply with quote
Idea I see Thumbs Up
I know what you mean with the clutch cable, damn fidly little thing when it comes out Brick Wall Laughing
PostPosted: 22:12 - 21 Jan 2007    Post subject: Reply with quote
Mmm, and mine seems to eat them. Put a new cable in and it is light and smooth for a couple of weeks, but rapidly gets heavier.
cestrian
PostPosted: 00:21 - 22 Jan 2007    Post subject: Reply with quote
I think the best thing to do is to remove the cover, clean the area with a cheap WD40 like spray (99p/ tin) and watch for leaks. There is a possibilty that oil may have simply collected behind that cover and maybe now its been disturbed. A clean up is not a bad thing anyway.
Just a thought....
Rookie
PostPosted: 00:45 - 22 Jan 2007    Post subject: Reply with quote
If it's the same as the Cat's setup, and it looks to be to me, that shouldn't be a problem, you just need to thread it back inside the sprocket cover and hook it back on. AFAIK though you shouldn't have to remove that black rubber thing to get at the sprocket, it's just the allen bolts, but I think there's 6, not 5... at least I remember tugging on the bugger for a good few minutes before realising there was one which was heavily recessed which I'd missed.
EDBANGER
PostPosted: 20:54 - 22 Jan 2007    Post subject: Reply with quote
Right then, tried that tonight, didn't seem to make much difference. Still not engaging with the engine and still leaking oil. Bugger, bugger, bugger! What now?
PostPosted: 21:06 - 22 Jan 2007    Post subject: Reply with quote
Right, take the adjuster bolt and locknut out. Stick the bike in gear (engine NOT running) and try and push it forward. See if the engine turns / compare it to with the adjuster in place.
The adjuster nut should go in fairly lightly. Just turn it until you can just feel resistance as it starts to push on the clutch pushrod (not tightened right up) and the back off a touch and do the lock nut up.
EDBANGER
PostPosted: 21:15 - 22 Jan 2007    Post subject: Reply with quote
So, take the nut and bolt out completely. Put it in gear. Am I right in saying that it shouldn't move if the clutch is out at this point?? Then put it back in and tighten it gradually until I reach the desired point??
PostPosted: 21:20 - 22 Jan 2007    Post subject: Reply with quote
If you take it out then the clutch should be fully engaged and it should be very difficult to push the bike forward (as the engine will turn, or the tyre skid). If it is fairly easy to push forward then you know the problem is not the adjuster.
With the adjust when you first turn it there will be next to no resistance, then you will get some resistance as you start to push on the pressure plate against the clutch springs, and then it will stop. Basically get to the point where you start to feel some resistance and then back off a touch.
EDBANGER
PostPosted: 21:32 - 22 Jan 2007    Post subject: Reply with quote
So if it still pushes forward with the nut and bolt completely out what else could the problem be?
PostPosted: 21:36 - 22 Jan 2007    Post subject: Reply with quote
Clutch pushrod out of position (check if there is a locating hole on the clutch actuating mechanism, on the inside of the sprocket cover). Clutch cable catching on something, pulling the mechanism, something like that.
If it is doing it with the adjuster out then take the sprocker cover back off and try again.
EDBANGER
PostPosted: 21:40 - 22 Jan 2007    Post subject: Reply with quote
Cheers Keith! I think next time I shall take pictures along the way just so you know what i'm on about. I'm not sure I know! Very Happy
The last post was made 19 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 101.66 Kb
