| EDBANGER |
 EDBANGER World Chat Champion
 Posted: 18:20 - 21 Jan 2007 Post subject: My god, what have I done??? Help needed! |
OK, so I changed my sprockets and chain today. An easy job, i've done it before, but this time I have somehow really made a bollox of it.
So here's my diagram to help explain my problem. I forgot to draw the clutch cable the goes into the cover just to the left of the rubber cover.
https://img.photobucket.com/albums/v693/smncttr2/public/bikeproblem.jpg
This is the cover I had to remove to get to the front sprocket. Now past experience tells me all I need to do was remove the 5 bolts, pull off the cover and we're done. This time however, after the bolts were remove the cover was loose but would now come off. I didn't want to use brute force so investigated further. I removed the rubber cover and found another bolt. I then (this is the bit where I think I fucked it up) undid that bolts. As a result the clutch cable came loose from the case. The case still didn't shift any further so I then applied the brute force. It came off, nothing broke, nothing fell out. I figure it was just all the oily, dirt that made it slightly hard to remove and I didn't need to undo that last bolt.
I changed the sprocket, reconnected the clutch cable into it's housing on the inside of the cover and put it all back together, tightening back up that screw that was under the rubber cover.
Now, the clutch seems to be perminantly on, I can change the gears, but when I put revs on, the bike doesn't move. Then after 5 minutes of head scratching I noticed oil coming from that general area, I couldn't find the exact source but there was no leak before I started.
If any of that made sense. What the hell have I done and how do I fix it? ____________________ If you can't spot the sucker in your first half hour at the table, you are the sucker. |
| EDBANGER |
| Whosthedaddy |
 Whosthedaddy Super Spammer
| Whosthedaddy |
 Posted: 22:05 - 21 Jan 2007 Post subject: |
I see
I know what you mean with the clutch cable, damn fidly little thing when it comes out  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| cestrian |
 cestrian World Chat Champion
| Rookie |
 Rookie World Chat Champion
| EDBANGER |
 Posted: 21:06 - 22 Jan 2007 Post subject: |
Right, take the adjuster bolt and locknut out. Stick the bike in gear (engine NOT running) and try and push it forward. See if the engine turns / compare it to with the adjuster in place.
The adjuster nut should go in fairly lightly. Just turn it until you can just feel resistance as it starts to push on the clutch pushrod (not tightened right up) and the back off a touch and do the lock nut up.
| EDBANGER |
 Posted: 21:20 - 22 Jan 2007 Post subject: |
If you take it out then the clutch should be fully engaged and it should be very difficult to push the bike forward (as the engine will turn, or the tyre skid). If it is fairly easy to push forward then you know the problem is not the adjuster.
With the adjust when you first turn it there will be next to no resistance, then you will get some resistance as you start to push on the pressure plate against the clutch springs, and then it will stop. Basically get to the point where you start to feel some resistance and then back off a touch.
| EDBANGER |
| EDBANGER |
 Posted: 21:40 - 22 Jan 2007 Post subject: |
Cheers Keith! I think next time I shall take pictures along the way just so you know what i'm on about. I'm not sure I know!  ____________________ If you can't spot the sucker in your first half hour at the table, you are the sucker. |
The last post was made 19 years, 248 days ago. Instead of replying here, would creating a new thread be more useful? |
