CG125 Speeding up Idle
iand
PostPosted: 12:52 - 22 Jan 2007    Post subject: CG125 Speeding up Idle Reply with quote
I have a 2001 51 plate CG125 CDI, is it possible to speed the idle up a little bit? even when it is fully warm the idle is very slow and occaisionally the bike stalls when waiting at the lights/junctions.
Any ideas?
Ian
Marci
PostPosted: 12:57 - 22 Jan 2007    Post subject: Reply with quote
Manual: See this thread - https://www.bikechatforums.com/viewtopic.php?t=104236&highlight=cg125+manual
Idle speed is controlled by a screw on the side of the carb.
EDIT: Sorry, link to manual now dead apparently...
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
PostPosted: 13:16 - 22 Jan 2007    Post subject: Reply with quote
Yep, adjust the idle screw by screwing it in (clockwise) to increase the idle speed. Do it a small amount at a time (no more than 1/4 turn) and let the engine settle between adjustments. Make a note of how much you moved it in case you want to put it back to how it was (always a good idea when messing with anything on your carbs).
When you have the idle speed set, you may need to use the cable adjuster to take up excessive slack in the throttle cable (leave a small amount of slack, couple of mm or so).
As it happens, I did a picture of a CG125 carb with the idle screw and cable adjuster marked in.
https://www.bikechatforums.com/download.php?id=29672
iand
PostPosted: 20:53 - 22 Jan 2007    Post subject: Reply with quote
thanks guys, will ahve a play around later and see if i can get it running a tad quicker for the missus!
Iand
The last post was made 19 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 39.9 Kb
