neutral light has gone !! help plz !!
Jamie S
PostPosted: 02:30 - 24 Jan 2007    Post subject: neutral light has gone !! help plz !! Reply with quote
Not a big problem just one thats pisses us off .
Right had the yam for a month now and when we first got it when neutral was selected then a green light came one .
but now if you put it in neutral there is no light
does any one know what it could be ?
The bike is a yammy xs 250 does any one no were the sensor is ?
It must have one to no when its out of gear shurely
cheers
jamie stokes
PostPosted: 02:47 - 24 Jan 2007    Post subject: Reply with quote
A blown lightbulb?
The simplest explanation is usually the best.
hmmmnz
PostPosted: 08:00 - 24 Jan 2007    Post subject: Reply with quote
lol, calm down, breath ...
do as stink whell says and check the bulb in the clocks first,
if its not that then look at the sensor (you'll see a wire going into the gear box side of the engine)
have fun Very Happy
the humans are dead
I kick arse for the lord
john2
PostPosted: 10:35 - 24 Jan 2007    Post subject: Reply with quote
You had not thought to check the bulb?
sagiliam
PostPosted: 10:39 - 24 Jan 2007    Post subject: Reply with quote
when that happened to mine, it turned out to be my indicator relay. Just a thought?
Jamie S
PostPosted: 10:45 - 24 Jan 2007    Post subject: Reply with quote
just to ask did the indicators still work ?
john2
PostPosted: 10:49 - 24 Jan 2007    Post subject: Reply with quote
Also, have you tried twisting the handlebars each side, because this happened to myne and it was a broken wire.
sagiliam
PostPosted: 10:57 - 24 Jan 2007    Post subject: Reply with quote
Erm honestly i cant remember.
The first time i know for definite that they didnt. But the second time, i think they did continue to work but the neutral light didnt. They are only around a fiver to replace. But check wires and bulbs first.
Ls
Jamie S
PostPosted: 12:03 - 24 Jan 2007    Post subject: Reply with quote
I have got one of them multy meter things i dont no how to use it tho lol could i check the bulb is working with that ?
or you got a better way.?
PostPosted: 13:14 - 24 Jan 2007    Post subject: Reply with quote
Well. The traditional way is to take the bulb out and look at it to see if the filament is broken.
Given that they can often be a fiddle to get at, you might want to fork out the 50p on a new one anyway and just fit it while you are in there.
Jamie S
PostPosted: 14:15 - 24 Jan 2007    Post subject: Reply with quote
broken bulb !
now all i got to do if get a new one from somewere
im thinking motorist shop ?
sagiliam
PostPosted: 14:26 - 24 Jan 2007    Post subject: Reply with quote
Confused No try a food shop Rolling Eyes
Places like halfords will be pricey.
Try somewhere like Wilco, if there is one near you,
Ls
Itchy
PostPosted: 14:31 - 24 Jan 2007    Post subject: Reply with quote
My neutral light is dodgy , riding you CAN sometimes get it to light up stopped at lights , it then flickers rapidly , the more you rev the more erm solid the light gets , when you stop you can kick it into neutral , then have to ding it on the side stand to make it come on , me thinks loose connector , affected by vibes , anybody any ideas?
Ta.
Jamie S
ok just thought i could take the bulb out of my other bike poissibly
Jamie S
PostPosted: 14:44 - 24 Jan 2007    Post subject: Reply with quote
and mate if you rev it and it goes brighter then your battery iz flat !-on its way out
Itchy
PostPosted: 14:48 - 24 Jan 2007    Post subject: Reply with quote
Nah , its not that I know its a loose wire , I'm just loathed to repair it , every thing else works fine.
Jamie S
PostPosted: 14:51 - 24 Jan 2007    Post subject: Reply with quote
does the main beam light go brighter when u rev it ??
Marci
PostPosted: 15:00 - 24 Jan 2007    Post subject: Reply with quote
Definitely sounds like loose wire or connector, or fractured filament that vibes itself back to make a connection in sympathy with the engine... not a battery power output issue.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
The last post was made 19 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 94.97 Kb
