NS125R-K headlight bulb options ?
Ian (GPX)
PostPosted: 16:34 - 12 Aug 2003    Post subject: NS125R-K headlight bulb options ? Reply with quote
Hi All,
Does anyone know if it is possible to change the headlight bulb for one that throws out more light ?
The bulb at the moment is 12v 25w/25w.
Honda dealer said that the max would be 35w/35w !
How can this be ? Can I not use a Halogen bulb ? If so what wattage should be OK to use on my NS125R-K without the need to upgrade the wiring ?
Also a link / address of a place to obtain said bulb.
Ian.
Lee
PostPosted: 17:12 - 12 Aug 2003    Post subject: Reply with quote
You could put a 55/60w bulb in, but I've heard people saying it melts the cables and warps the headlight glass (well, plastic). I know what you mean though, 25w is like trying to light the road using your mobile phone screen Smile 35w seems to be what most people use if they upgrade.
You can order them from www.Beedspeed.com
Lee
Ian (GPX)
PostPosted: 22:40 - 12 Aug 2003    Post subject: Reply with quote
Hmm ! Anyone else got any info for me ?
Is there a conversion kit ?
EuropeanNC30R...
Gay Hairdresser
PostPosted: 22:56 - 12 Aug 2003    Post subject: Reply with quote
If it's a standard fitting(and it probably is), the new bulb should pop right in.
Ian (GPX)
PostPosted: 23:09 - 12 Aug 2003    Post subject: Reply with quote
Yes, I know this, but I want to know if I can put in a higher rated bulb like as in 45/40w ?
Has anyone done this to their NS125R-K ?
What I would really like to do is fit a 60/55 bulb if one can be found, but alas no luck so far.
Could I change the headlight unit for another one that uses a higher watt bulb and will the bikes electrics / wiring stand up to the extra drag in power without the need to upgrade the wiring ?
I have looked all over the place on the internet for some info on this and came up blank ! Sad Mad Evil or Very Mad
EuropeanNC30R...
Gay Hairdresser
PostPosted: 23:19 - 12 Aug 2003    Post subject: Reply with quote
I don't want to sound like Stephen here(Razz), but you'd do well to search through previous posts on this site. I'm sure it's been covered before, you know a lot of the people on here riding Blades and the like had NSR's a little over a year ago. Wink
Robby
Dirty Old Man
PostPosted: 23:30 - 12 Aug 2003    Post subject: Reply with quote
NS headlight wasn't all that bad, i had one.
It will be a standard size bulb, so just find what it is or get it out and pop down to halfords and get a 45 or 55 watt version. Its very unlikely to melt anything - I think my little fairing has a 80 or 100 watt bulb when standard is 45, it feels very hot an inch or 2 in front of it, but it works.
PostPosted: 00:38 - 13 Aug 2003    Post subject: Reply with quote
Standard is a 35/35. You could probably get away with a larger bulb, but I am not sure how much larger. It is possible to melt a headlight, but not that likely. However not sure if halogen bulbs are a touch hotter.
My early AF1 had a 45w headlight bulb but I have run it as a 60w for years. I had a 100/80w bulb in the FZ for a few years which worked well, but that melted the wiring. Avoiding this problem is easy if you use the standard wires to trigger a relay, and then run wires from the battery through the relays to actually provide power to the headlights
Ian (GPX)
PostPosted: 12:11 - 13 Aug 2003    Post subject: Reply with quote
OK, just been to my local Honda dealer in Surbiton and had a look at the book that they have on the NS125R-K/F and it seems that there are two versions of the head lamp unit.
The version I have uses the 25/25w bulb and the other version allows you to use a 60/55w halogen bulb, but get this, the headlight unit costs over £180.00 ! Shocked Also the bulb fitting is not the same and requires a new bulb holder which is included in the replacement hedlight unit.
OK, now I need to find a breaker thats got this headlight unit that uses the 60/55w bulb in stock, anyone have any info ?
The last post was made 23 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 60.08 Kb
