temp gauge -- confusing me
befdelta7
PostPosted: 15:09 - 25 Jan 2007    Post subject: temp gauge -- confusing me Reply with quote
hello people.
my temp gauge isnt moving when the engine is warm it just stays on the resting needle, but when i touch the wire on to the cylinder it rockets up to the max. this does this on any metal part of the engine EG bolts, screws, cylinder wall, cylinder head. but only when the ignition is turned on. everything else works but the temp gauge.
any ideas what i could check to solve the problem of the temp gauge not working?
iv put a new connector on the end of the wire as the old one was corroded a bit but it still refuses to work Crying or Very sad
thanks for your replys and help!! Thumbs Up Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
hmmmnz
PostPosted: 15:12 - 25 Jan 2007    Post subject: Reply with quote
sounds like your sensor is poked, when you touch it to the engine you are completing the circuit,
the sensor changes resistance as it heats up, hence how the guage comes up with a reading that is accurate, in your case its an open circuit and the guage thinks its icy cold water being pumped about Very Happy
get a new sensor Thumbs Up
the humans are dead
I kick arse for the lord
befdelta7
PostPosted: 15:18 - 25 Jan 2007    Post subject: Reply with quote
cheers for that! Thumbs Up
my sensor's pin which the wire connects to did move up and down. when it was up noting happened so i glued it down and it worked fine up untill now.
finpos
PostPosted: 15:26 - 25 Jan 2007    Post subject: Reply with quote
What he said, but also check you actually have some coolant in your radiator first. Smile
finpos.
hmmmnz
PostPosted: 16:33 - 25 Jan 2007    Post subject: Reply with quote
oh yeah Very Happy water... lol, make sure you have that in your bike or all my advice means nothing Very Happy
good spotting finpos Mr. Green Thumbs Up
the humans are dead
befdelta7
PostPosted: 17:52 - 25 Jan 2007    Post subject: Reply with quote
theres water and antifreeze in there, rads full. yesterday i was riding it and the temp reading was 47*C the needle stopper is at 40*C so was working yesterday, could it be the cold weather that would make the temp gauge not work? i mean keeping the engine temp below 40*C not accually causing the temp gauge to stop working Laughing
hmmmnz
PostPosted: 18:05 - 25 Jan 2007    Post subject: Reply with quote
lol, no,
chances are the terminals are buggered, try taking the connectors off, and gently sanding the terminals, to try and get better contact, failing that, it'll be inside the unit itself and will need to be replaced
the humans are dead
befdelta7
PostPosted: 18:53 - 25 Jan 2007    Post subject: Reply with quote
hmmm supose.....
cheers hmmmnz.
any idea where i can get a new sensor and an idea of price?
Jamie S
PostPosted: 19:22 - 25 Jan 2007    Post subject: Reply with quote
ebay
collywog19
PostPosted: 19:49 - 25 Jan 2007    Post subject: Reply with quote
hi, i have a temp sender for sale also breaking a full supercity bits are on ebay,
Pm me
cheers
col
1996 Yamaha YZF750R, 1994 Yamaha YZF750R, 1989 Honda CBR400RR NC29, 1995 Kawasaki GPX 250R AND 1995 Cagiva Mito Evo SP!
The last post was made 19 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 65.92 Kb
