nsr125 air filter hose
mansong001
PostPosted: 19:41 - 25 Jan 2007    Post subject: nsr125 air filter hose Reply with quote
air filter hose has come off from air filter on my nsr 125 on the far end.where does this connect too.is it difficult,its causing sluggish start/smoke
dave madden
alains
PostPosted: 20:06 - 25 Jan 2007    Post subject: Reply with quote
bring a picture Cool
Jinkz
PostPosted: 20:20 - 25 Jan 2007    Post subject: Reply with quote
Agreed, I think he means the rubber connector between the box and the carb?
mansong001
PostPosted: 20:40 - 25 Jan 2007    Post subject: re: Reply with quote
ai thats the one.its a blue rubber hose.its connected to the filter box in front but nothing else.where and how can i get this connected.im very worried on this one.is it possible to drive like this without fucking the engine up
dave madden
Jinkz
PostPosted: 20:43 - 25 Jan 2007    Post subject: Reply with quote
It sounds like you still have it there, and it's just disconnected. It sits on the top of the carb in a kind of backwards position, but if you don't connect it to the air box properly this will cause smoke (1st hand experience). You need to open the air box top and pull the rubber connector through and you'll see the seals.
Don't attempt to ride it about without fixing this as the engine isn't getting the right air mix it needs and will fuck it up!
mansong001
PostPosted: 21:11 - 25 Jan 2007    Post subject: Reply with quote
i drove it areadt a couple of miles earlier but not since.how do i get it into the carb.not a great view man.
dave madden
moonym20
PostPosted: 21:24 - 25 Jan 2007    Post subject: Reply with quote
Really mate you need to pull the tank off the bike, then remove the airfilter box, place the rubber back into the airbox as it should go then gently place the rubber back over the carb, tighten the jubilie clip, secure the airbox and put the tank back on.
Sorted Cool
A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot Smile
mansong001
PostPosted: 21:56 - 25 Jan 2007    Post subject: Reply with quote
why take the tank off moony?is this hard?if i left it on can you still not get to the carb.is there a slot in the carb for this hose to go
dave madden
alains
PostPosted: 01:32 - 26 Jan 2007    Post subject: Reply with quote
now , i know what you are talking about . the shape of the air box cover make a bowl in front on top . water can accumulate in it , this why they put a plastic blue pipe to keep it empty and the pipe guide the water out of the electrics
The last post was made 19 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 59.5 Kb
