Tubed and tubeless tyres and blowouts?
froggeh
PostPosted: 10:06 - 28 Jan 2007    Post subject: Tubed and tubeless tyres and blowouts? Reply with quote
Ok, As I am considering getting a trail or dual purpose bike for my main ride I was just wondering about the safety of tubed tyres?
Are the more off-road tubed tyres more prone to blowout?
And if so is there anything you can do to reduce the risk?
Or is it something just not to worry about?
Finglonga
PostPosted: 11:13 - 28 Jan 2007    Post subject: Reply with quote
Tubed tyres are better as there are two items that must fail before the blowout. If the tube goes first you will have a slow deflation and if the tyre goes first you will feel it and stop before the tube has time to go.
Had one years ago with a tubless tyre (rear) and it was nasty. Just managed to keep it in a straight line...Now if it was the front.. Shocked Shocked Shocked Shocked
Andy Sez....
F.Y.Y.F.F.
PostPosted: 12:16 - 28 Jan 2007    Post subject: Reply with quote
Tubeless tyres should be less prone to blowouts.
However neither should be occuring that often. Make sure that you are using a tyre designed to run with a tube, or at the very least a tube designed to go in a tubeless tyre (tubeless tyres are a lot less finished on the inside, which damages inner tubes).
Itchy
PostPosted: 13:00 - 28 Jan 2007    Post subject: Reply with quote
you can get wire wheels sealed up for £35 a wheel so they can take tubeless tyres , I've got the link somewhere since I was going to give the link to Joe.
which is kind of interesting wonder if they'd make a ZX10R with wire wheels to save even more weight and get a 1:1.2 weight to power ratio.
froggeh
PostPosted: 13:04 - 28 Jan 2007    Post subject: Reply with quote
I would have thought a blowout on a tubed tyre would be worse.
On a tubeless tyre surely the thickness of the rubber slows down the speed of air escape?
Finglonga
PostPosted: 14:11 - 28 Jan 2007    Post subject: Reply with quote
Didn't with mine....When it went it went bith a big fecking bang and thew the bike sideways. There was a 4" hole in the sidewall. Confused
Andy Sez....
F.Y.Y.F.F.
froggeh
PostPosted: 20:03 - 28 Jan 2007    Post subject: Reply with quote
yikes Neutral
But I wonder if this is unusual. I have had a puncture in the car and not even realized for 2 days, because the nail essentially plugged the hole.
That wouldn't happen in a tube surely?
PostPosted: 20:08 - 28 Jan 2007    Post subject: Reply with quote
Not likely, no.
Skudd
PostPosted: 23:52 - 28 Jan 2007    Post subject: Reply with quote
Used tubed tyres for 20 odd years had blow outs but stayed upright. Had slow punctures and didn't. Punctures in general are not a common thing really though. ( Tubed tyres are cheeper to repair )
I've run on tubless tyres for the past 3 years but have puncture seal added just incase, but again punctures are rare so don't get all worked up. Unless your name is Hammond and you are driving a jet car at 288 mph then punctures are worth noting. Shocked Smile
PostPosted: 00:31 - 29 Jan 2007    Post subject: Reply with quote
Don't worry about the type of tyre. I've run tubes in tubeless tyres loads of times. In fact, on my last bike, they were standard equipment. I was running ME Z1s on wire wheels.
At worst, the tyres will heat up more quickly with a tube in. Unless you are doing silly mph approaching the speed rating of the tyre, this is actually likely to be more an advantage in this country. Certainly not an issue on a trailie.
In short, don't worry about it. If the tyre is going to blow out, it means it has either had a huge hole slashed in the side of it by something sharp or there is a serious defect in the tyre itself. I doubt the presence or otherwise of a tube will make a hell of a lot of difference in either situation.
froggeh
PostPosted: 01:12 - 29 Jan 2007    Post subject: Reply with quote
Did u watch it earlier Smile Way cool. Glad the mad bastard is alive and well enough to put the curly headed moron in his place.
Finglonga
PostPosted: 11:50 - 29 Jan 2007    Post subject: Reply with quote
froggeh wrote:
yikes Neutral
23 Years of riding and only ever had one blowout, a puncture wouldn't do the same(I have had loads of them). Not even worth worrying about. Wink
Andy Sez....
F.Y.Y.F.F.
froggeh
PostPosted: 12:22 - 29 Jan 2007    Post subject: Reply with quote
Ok this is what I mean... Thanks for the link Itchy
https://www.motorcyclecruiser.com/tech/tubeless_tire_seal/
and a quote...
However, the biggest drawback is that most wire wheels (there are exceptions, such as BMW) use tube-type tires — that is, tires that require inner tubes to hold the air that supports the motorcycle. Inner tubes entail a risk of rapid deflation (or blowout) and resulting loss of control if punctured because a punctured tube immediately loses its air. Tubeless tires, on the other hand, usually release pressure slowly, which can give you sufficient warning to get off the road safely.
Finglonga
PostPosted: 18:13 - 29 Jan 2007    Post subject: Reply with quote
Worth remembering that Moto cross bikes have tubed tyres. They go to hell and bak and you don't see them having problems. Mr. Green
Andy Sez....
F.Y.Y.F.F.
PostPosted: 21:43 - 29 Jan 2007    Post subject: Reply with quote
Yeah, but it is a cold frozen hell, not the hot hell they would get on the road.
The last post was made 19 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 89.59 Kb
