honda 125 HELP !!1
lilactime
PostPosted: 11:16 - 03 Feb 2007    Post subject: honda 125 HELP !!1 Reply with quote
bought old honda 125 , for work run . goes well , but if you old it at 40 to 50 the engine jerks and holds back , keep it flat out and its fine . changed plug , cleaned carb , electronic egnition . any ideas ?
lilatime
WavyGravy
PostPosted: 11:56 - 03 Feb 2007    Post subject: Reply with quote
Sounds like a classic case of partly obstructed mesh filter in the petrol tap, second choice dirty air filter, closely followed by corroded connector somewhere in the ignition system - if it's really 'old'.
You didnt say how old the bike is or what model, mine is 30+ year old 125S and thats where i'd look for this sort of problem,
If none of the above solves it then take it for a run and see if it happens at high revs in all gears, do a plug pull and post back, by then the post may have been moved to the workshop section
Good Luck!
Also thinking it might be the needle in the carb, if the bikes been stood a long time at some stage the needle can get coated, or might have been bent during cleaning
1975 CB125s, 1991 GN250, 1990 Ducati Paso 906
"Don't wake him up - He's got insomnia - He's trying to sleep it off"
The last post was made 19 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 31.38 Kb
