speedfight engine wont start
infestedheale...
PostPosted: 18:31 - 03 Feb 2007    Post subject: speedfight engine wont start Reply with quote
hello, i got a peugeot speedifight 2, 100cc, my engine wont seem to start, the battery had originally ran out, but now its charged, i try n start it and it just wont, it jus keeps bumping, and smoke comes out the back each bump only a lil, but the smell of petrol is present, the kickstart wont work atall, its as if the joint has rubbed down and is broken, the battery is 100% fine, but the kickstart is gone, ANY IDEAS what could be wrong? i was thinking of taking the side of the engine off to check out to see if it was slipping or what.
chris1-4-7
PostPosted: 18:44 - 03 Feb 2007    Post subject: Reply with quote
Just take your side transmission cover off and you can then have a closer inspection. The teeth may have ground off the kick-start or may be out of position. Post some pictures up if you can mate so we can have better look. Wink
Chris (Brum)
element
PostPosted: 20:28 - 03 Feb 2007    Post subject: Reply with quote
Speedfights have imobilisers and they are a pain in the arse when things go wrong. Can you get a spark?
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
infestedheale...
PostPosted: 21:22 - 03 Feb 2007    Post subject: Reply with quote
yer the immobilisor is fine, its still flashin red light,btw can sum1 tell me where i could find a new gear, or what may have been ground down on the kickstart,a link to ebay or something or a website?
element
PostPosted: 22:19 - 03 Feb 2007    Post subject: Reply with quote
normally the teeth on the cog, connected directly to the kickstart lever shaft, chip off. Thats whats happened to mine and its quite common. Best bet is to find a spare complete casing as Ive never seen that individual cog on ebay... I missed one on ebay which was local and went for £7 Rolling Eyes Crying or Very sad Then you'll have the casing itself to either keep as a spare or sell off for the price you paid for it Thumbs Up
infestedheale...
PostPosted: 22:32 - 03 Feb 2007    Post subject: Reply with quote
stupid as this sounds, i cant find one, maybe cus im not sure what to search for? casing, lever? errm, wouild a link be possible? to ebay or something
infestedheale...
PostPosted: 14:40 - 05 Feb 2007    Post subject: Reply with quote
is this casing the one i need? https://cgi.ebay.co.uk/Peugeot-Speedfight-100-2002-final-drive-casing_W0QQitemZ300073713711QQihZ020QQcategoryZ122301QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Timmeh
PostPosted: 18:11 - 05 Feb 2007    Post subject: Reply with quote
does it look the same as yours? Same year? Same cc? Same bike?
If all four are yes, then it is.
chris1-4-7
PostPosted: 18:35 - 05 Feb 2007    Post subject: Reply with quote
Sound's to me that your starter motor is on it's last legs!
Chris (Brum)
bearwood.beckham
PostPosted: 18:40 - 05 Feb 2007    Post subject: Reply with quote
Exactly the problem I have at the moment. I only have a 50cc Speedfight 2. When it tryed to start it would squeal with slight smoke and a burst of it actually trying to start. I checked the plug, battery and fuse and there all fine. Now when the ignition is on Indi's and rear light work, but when I try to start it, all I hear is a click coming from around where the battery is. It won't try to turn over at all. I've been told that it's the starter motor.
Hope this helps.
infestedheale...
PostPosted: 08:58 - 06 Feb 2007    Post subject: Reply with quote
the picture does look exact like mine, mines a 52 plate, well it does start, i would say the perfect way to describe it, is how it sounds on a FREEZING morning, just makes that inicial starting sound over and over, and like i said, the kickstart is completely worn down im guessing, would the fact the kickstart is worn down afect the actual electric start?
infestedheale...
PostPosted: 11:03 - 07 Feb 2007    Post subject: Reply with quote
ok trying to take the side cover off the engine, and i can get 3 nuts off, and i cant move the others a INCH! any ideas atall how to do this? i even tried drilling through it with no luck i spend so long trying it. any ideas
chris1-4-7
PostPosted: 20:45 - 07 Feb 2007    Post subject: Reply with quote
They may have some thread glue on them. What i usually do with tight bolts is put the allen key in.(Long length in the bolt). Then i just grab an adjustable with a hole on the end, I then latch it on the end of the allen key and off it comes. Just be careful as they are very easy to thread and not so easy to get rid off once threaded. Good luck.
Chris (Brum)
infestedheale...
PostPosted: 20:48 - 07 Feb 2007    Post subject: Reply with quote
i really do apriciate the help from everyone! thanks guys, just one more question, does ANYONE have a clue, or a link as to where i can buy a cog to replace? i cant find one anywhere!! and does anyone know how much roughly they cost?
infestedheale...
PostPosted: 15:48 - 09 Feb 2007    Post subject: Reply with quote
ive taken the side cover off the engine, and i see a big elastic band type thing, what turns fine when i electric start it, but it wont start the engine still! im really confused, any ideas what else it could be?!
andys675
PostPosted: 22:44 - 09 Feb 2007    Post subject: Reply with quote
what voltage is you battery putting out? they need a good new battery to start, the immobiliser only stops them from revving up, not starting, the batter needs to be over 13V on a tester to wind it over fast enough, the batteries are cheap from new and you say it was flat and you charged it but you may need a new one anyway
infestedheale...
PostPosted: 22:49 - 09 Feb 2007    Post subject: Reply with quote
yer but it wont even start when connected to the mains through charger, thats why im so confused, like i said, the kickstart is totally loose now, would that make a difference? also, someone said something about the starter motor? how do i know if its that?
element
PostPosted: 17:13 - 10 Feb 2007    Post subject: Reply with quote
that side casing on ebay is useless to you since the kickstart spline isnt sticking out so it looks like it doesnt come with any of the parts you need..
the cog you are looking for I have never seen seperatly on ebay.
I got a speedfight haynes manual here somewhere. Ill dig it out...
Never had a problem getting the bolts out either. Sounds to me like copper grease wasnt used previously or someones used different bolts maybe.. You said you tried drilling them out?
Also sounds to me like its trying to turn over but theres something preventing it kick over. Stupid question but have you tried giving it a flick of the throttle when pressing the leccy start?
Few things that have stopped my speedfight starting in the past... Fell over once and couldnt start it for love nor money. Eventually started after 3 or 4, 10 second bursts on the leccy start. Another time the fuel vacuum hose had split and it wouldnt start..
Also was it running fine until the battery died?
The last post was made 19 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 96.97 Kb
