Bike still wont start
Silky
PostPosted: 14:22 - 07 Feb 2007    Post subject: Bike still wont start Reply with quote
Hi,
Just need to know whether or not to replace my coils.
They are reading below the suggested ohmic readings in the manual and the bike wont start, but all the plugs are still sparking.
Too weak a spark?
Tried everything else.
Have ya ever drunk Baileys from a shoe? IM OLD GREGG!!!
finpos
PostPosted: 14:35 - 07 Feb 2007    Post subject: Reply with quote
Probably not - as long as you are getting a decent spark off them, you should be OK. I'd be very suprised if two(?) coils failed simultaniously and exactly the same way to stop the engine running.
finpos.
Silky
PostPosted: 15:34 - 07 Feb 2007    Post subject: Reply with quote
Well, one coil is giving a slightly better reading, but i thought the same as you finpos.
Grrr, this is really pissing me off now. It must be the mixture. Ive replaced the leads, plug caps, stripped the carbs and cleaned the plugs.
Might have to bite the bullet and call the local spanner monkey.
finpos
PostPosted: 15:46 - 07 Feb 2007    Post subject: Reply with quote
As a desperate measure, try pouring a puddle of petrol into the bottom of your airbox - it'll richen the mixture up for a bit and might help it start. If it works, you probably have a problem with the cold-start enrichment circuit on the carbs.
finpos.
Silky
PostPosted: 16:01 - 07 Feb 2007    Post subject: Reply with quote
I'll have a go at re-setting the mixture first. But im unsure of your suggested method finpos? Do you mean the vapour from the fuel will be enough?
finpos
PostPosted: 16:08 - 07 Feb 2007    Post subject: Reply with quote
That's about the size of it. See also cans of "Easy-Start" you buy in halfords Smile
I wouldn't bugger about with the mixture until the bike is running and up to temperature.
finpos.
The last post was made 19 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 47.25 Kb
