| phil_DT |
 phil_DT Nova Slayer
| derbi x-treme |
 derbi x-treme Nova Slayer
| phil_DT |
 phil_DT Nova Slayer
 Posted: 09:56 - 08 Feb 2007 Post subject: |
just had a look inside the carb and the noise seems to be the floats??ive cleaned out all the jets and re-assembled. bike still wont go tho!  ____________________ 1992 DT80MX with Gianelli zorst and Mallosi Carb. Goes through engines faster than tyres..... |
| phil_DT |
 phil_DT Nova Slayer
 Posted: 10:35 - 08 Feb 2007 Post subject: |
alrite now i think its proper fucked! the engine will not turn over at all. the kickstart is stuck solid and when i try and bump start it, the wheel just locks up and nothin happens i suppose this is going to be expensive??? ____________________ 1992 DT80MX with Gianelli zorst and Mallosi Carb. Goes through engines faster than tyres..... |
| Marci |
 Marci Brolly Dolly
 Posted: 15:57 - 08 Feb 2007 Post subject: |
What gear are you trying to bump it in?? Sounds like it could have siezed...
Did you have antifreeze in coolant? ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| Dalemac |
 Dalemac World Chat Champion
| Marci |
 Marci Brolly Dolly
 Posted: 16:03 - 08 Feb 2007 Post subject: |
It's snowing out. Therefore it's cold out. If he DIDN'T have antifreeze in his coolant, then his coolant may have frozen. As water freezes it expands. This could have caused it to force it's way thru the gasket or even split the barrel or head internally, causing zero compression and possibly a siezure of the piston. If it's gotten past the gasket, it could then have flowed into bottom of engine and frozen overnight... effectively meaning nothing will move until it's defrosted, however then he'll have a load of water sloshing around within the engine, meaning it still won't start. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| Dalemac |
| Marci |
 Marci Brolly Dolly
 Posted: 16:10 - 08 Feb 2007 Post subject: |
It COULD happen to anyone who doesn't use antifreeze, hence antifreeze exists. All depends on the temperature of the area in which you keep your bike. EG: Outside overnight - DEFINITELY use antifreeze. In a garage attached to a house that has central heating - may get away without it, but still wouldn't risk it.
I personally don't use any, but I use alternative stuff that does the same job by coincidence.
Always best to have some in than none at all. A £5 bottle of antifreeze could well save you from having to buy a £100 cylinder. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| Finglonga |
 Finglonga World Chat Champion
| Dalemac |
| Dalemac |
 Posted: 16:15 - 08 Feb 2007 Post subject: |
oh im aircooled. stupid idiot.
will teach me to know nothing about my own bike. ____________________
YBR125 -> GPZ500S -> SL1000 |
| phil_DT |
 phil_DT Nova Slayer
 Posted: 20:07 - 08 Feb 2007 Post subject: |
mine is aircooled aswell. wel ive bin tryin all day but the engine is defo seized! i took the spark plug out and there was a little pin stuck in the side of it???? i presume some type of piston pin or??? well anywayz it isnt a good sign ahh well just gives me an excuse to fit a big bore kit haha  ____________________ 1992 DT80MX with Gianelli zorst and Mallosi Carb. Goes through engines faster than tyres..... |
| wisebeuy |
 wisebeuy Nova Slayer
 Posted: 20:10 - 08 Feb 2007 Post subject: |
Not sure what bike you're riding, is it 2-stroke? Perhaps noise was something to do with oil pump? If that isn't working then big and small end will go no lubrication and will seize.
Not trying to scare you, just offering it as a possibility
Andy |
| phil_DT |
 phil_DT Nova Slayer
 Posted: 20:24 - 08 Feb 2007 Post subject: |
yer, when i get the BB kit im removing oil tank and pump. i will just premix in the tank. its just guttin that when it snows i got no bike to go for a burn on!  ____________________ 1992 DT80MX with Gianelli zorst and Mallosi Carb. Goes through engines faster than tyres..... |
| Pete. |
 Pete. Super Spammer
| phil_DT |
 phil_DT Nova Slayer
 Posted: 21:54 - 08 Feb 2007 Post subject: |
the pin i found in the spark plug was about 4mm long and about the diameter of a pencil lead? tommorow i will strip engine down and have a look at what the damage is im not impressed only been on the road for a week after spending £600 getting it through the MOT not good. ____________________ 1992 DT80MX with Gianelli zorst and Mallosi Carb. Goes through engines faster than tyres..... |
| Pete. |
 Pete. Super Spammer
 Posted: 23:00 - 08 Feb 2007 Post subject: |
Sounds like the piston-ring stop-pin. It's job is to keep gap in the piston ring away from the ports, or the end of the ring pings out and snaps off. If the pin has come out, your piston is scrap and your barrell will be damaged. ____________________ a.k.a 'Geri'
| phil_DT |
 phil_DT Nova Slayer
| wisebeuy |
 Posted: 03:17 - 09 Feb 2007 Post subject: |
If you can be arsed to do premix, then thats your best option, is the only way to make sure your bike gets the correct mix. But look on the brightside, its a good excuse to get the big bore kit
Hope you get back on the road soon.
Andy |
| phil_DT |
 phil_DT Nova Slayer
The last post was made 19 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
