| T1z3R |
 T1z3R World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
 Posted: 10:59 - 08 Feb 2007 Post subject: |
Clean all the oil off and then have a look where the leak is coming from.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| T1z3R |
 Posted: 11:00 - 08 Feb 2007 Post subject: |
as i said ive just got to work so not going to be able to do anything for the next 7 hours or so but thanks for your input all the same  ____________________ duck my sick! |
| Finglonga |
 Posted: 12:43 - 08 Feb 2007 Post subject: |
Could be anything, your the only one that can tell, if its coming from the gear linkage shaft then chances are its the seal...or the output drive shaft seal??  ____________________ Andy Sez....
F.Y.Y.F.F. |
| T1z3R |
| veeeffarr |
 veeeffarr Super Spammer
| T1z3R |
 Posted: 13:08 - 08 Feb 2007 Post subject: |
thanks Toby, i was pretty sure it might be that was just looking for the opinion of a GS owner to confirm or deny
not really worried so much but its the kind of problem im liable to let get worse  ____________________ duck my sick! |
| veeeffarr |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 21:48 - 08 Feb 2007 Post subject: |
yep oil seal on the gear selector, fairly common,
i should really get around to doing mine.... nah fuck it
its a matter of digging the old one out and pushing a new one in,
not a real major,
you just have to take the sprocket cover off, gear lever, and drain the oil don't forget that:D ____________________ the humans are dead
I kick arse for the lord
| instigator |
 instigator Super Spammer
 Posted: 21:51 - 08 Feb 2007 Post subject: |
T1z3r, buy one tomorrow (google fowlers suzuki), it'll arrive on saturday morning and can be fitted on Sunday. Be about £6 inc delivery at the most.
Or do it the t1z3r way, wait until the bike has dumped all of it's oil and running dry, blown the engine and THEN look to replace the gasket on the dud engine.
| Method |
 Method World Chat Champion
 Posted: 22:25 - 08 Feb 2007 Post subject: |
Yep, gearbox output shaft seal.
However, there is one other option that may be causing this, i had the same problem earlier last summer.
Basically the way the damn front sprocket cover is made, all your chain lube and gunk from the road collects behind that casing, when you lube your chain or you get some water up there from the road or rain etc, it hits the top of the sludge pile that has collected behind the casing, and dribble straight off down the side of the gear lever and that side of the cover. As its dribbling from the top of the sludge pile you find that it looks black and can be mistaken for oil
Check that first, but you should be able to tell as soon as you take that cover off, very easy to do - about 5 bolts and your in. You just need to take your gear lever off first  ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
| veeeffarr |
| Method |
 Posted: 22:27 - 08 Feb 2007 Post subject: |
Its 8mm and its easier to use a socket for all the bolts. ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
| veeeffarr |
| Method |
 Posted: 22:28 - 08 Feb 2007 Post subject: |
| T1z3R |
 Posted: 22:31 - 08 Feb 2007 Post subject: |
thanks folks.
all my effin tools are in gregs shed
will get it checked on saturday most likely ____________________ duck my sick! |
| veeeffarr |
| funmonkee |
 funmonkee Super Spammer
| T1z3R |
 Posted: 23:42 - 08 Feb 2007 Post subject: |
not even close  ____________________ duck my sick! |
The last post was made 19 years, 283 days ago. Instead of replying here, would creating a new thread be more useful? |
