Hornet Starting Problem
chris___
PostPosted: 20:29 - 10 Feb 2007    Post subject: Hornet Starting Problem Reply with quote
My mate brought a 99 Hornet 600 today and is having problems starting it.
The battery is showing full charge but when we hit the starter it was making the sound it makes when the battery is dead. We rigged up a booster to the battery and it started OK, and it'll bump start too.
After riding around 40 miles after bumping it it still wouldnt start off the starter.
Cheers for any help
Chris Thumbs Up
Yamaha rxs100 > Kawasaki ZZR600 > Kawasaki ZX6R > Honda Hornet 600 > Honda Bros 400 > Suzuki SV650S K2
Bikepics page
baldy
PostPosted: 20:32 - 10 Feb 2007    Post subject: Reply with quote
The battery is buggered, get a new one. I would also check the regulator to see if it charging properly.
One day i will rule the world, just not today.
chris___
PostPosted: 20:56 - 10 Feb 2007    Post subject: Reply with quote
sorry forgot to mention, the battery was showing a full charge of 12volts on the meter.
I was thinking maybe a reg/rec problem?
Bikepics page
stu_m
PostPosted: 23:31 - 10 Feb 2007    Post subject: Reply with quote
try looking at the connections to the battery too usually overlooked but a common problem
give them a clean up on the battery and the cables too
Stu
Paddy Blake
PostPosted: 05:47 - 11 Feb 2007    Post subject: Reply with quote
The battery may seem ok but when you push the starter button the voltage drops.You will find that if it does not start first time that the charge soon runs out.Change the battery.
I had to get a battery every six mounts or so on my 99 hornet.
Gazdaman
I did a trackday!!!
PostPosted: 14:01 - 11 Feb 2007    Post subject: Reply with quote
Measuring 12v with no load on the battery is meaningless.
Get a bit of load on it (more than a bulb) and I bet you'll find it puts out nearly nothing.
New battery time, they wear out.
Gaz
chris___
PostPosted: 14:17 - 11 Feb 2007    Post subject: Reply with quote
Cheers for the reply guys Thumbs Up
I'll tell him to get a new battery and give it a go then.
Chris
Bikepics page
The last post was made 19 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 51.19 Kb
