bandit running trouble
stu_m
PostPosted: 23:16 - 10 Feb 2007    Post subject: bandit running trouble Reply with quote
a work mate has been having trouble with his bandit
and very cold days it runs like a bag of spanners wont idle or run properly at all
but if he sticks it in the garage it runs spot on its just as soon as you get outside riding it, it run crap again
he took the plugs out and they where black so got new ones then a few days later the same thing running crap black plugs etc etc
personally i think its carb icing
any one got any suggestions
Stu
Ciarans-special
PostPosted: 11:14 - 11 Feb 2007    Post subject: Reply with quote
Sounds like its more than likely the air filter to me,did he check it? Confused
stu_m
PostPosted: 12:49 - 11 Feb 2007    Post subject: Reply with quote
yup checked cleaned and even a new one fitted
stu
Gazdaman
I did a trackday!!!
PostPosted: 13:52 - 11 Feb 2007    Post subject: Reply with quote
*DING* The correct answer is carb icing.
Bit of proFST in a tank of fuel and it'll be reet as rain.
Gaz
PostPosted: 14:23 - 11 Feb 2007    Post subject: Reply with quote
Is it a UK spec bike? Have a feeling UK spec 600 Bandits had carb heaters.
Gazdaman
I did a trackday!!!
PostPosted: 22:30 - 11 Feb 2007    Post subject: Reply with quote
Mine has little brass connectors on the bottom of the carbs, but mine suffers from icing fairly badly.
Apparently the controlling switch goes up the spout fairly regularly.
And I read somewhere that it was only the newer model bandit 600s that had carb heaters, i.e 2000 +
Gaz
timjim
PostPosted: 23:05 - 11 Feb 2007    Post subject: carb heaters Reply with quote
The early Bandits ,before about 97,didnt have carb heaters from standard,but if presented to a Suzuki dealer while in warranty,then Suzuki would fit them.The carb heaters do help,but not totally cure the fault of carb icing.Mixing Silkolene ProFST does help a lot .
slj23
PostPosted: 23:25 - 11 Feb 2007    Post subject: Reply with quote
is redex the same as silkolene profst
'isn't it enough to see that a garden is beautiful without having to beleif that there are fairies at the bottom of it too?'
PostPosted: 00:02 - 12 Feb 2007    Post subject: Reply with quote
No. Redex is meant to reduce carbon buildup. All sorts of other claims for it, but the Silkolene stuff is designed to stop carb icing.
The last post was made 19 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 60.14 Kb
