Audio Editing - remove/reduce windblast?
Rhys
PostPosted: 21:58 - 11 Feb 2007    Post subject: Audio Editing - remove/reduce windblast? Reply with quote
is there some software in particular that can edit the audio track of a video and try to reduce windblast noise? i just thought with windblast adding a similar noise on different cameras that there may just be a solution?
i can hear engine sound in my vids, i dont want to just add music though..
cheers,
Rhys
Current Bike: '94 RVF 400R
Bike Pics Youtube Myspace
Trip
PostPosted: 02:24 - 12 Feb 2007    Post subject: Reply with quote
What program are you using to edit?
Rich
Bike: Yamaha XJ600N Mileage: 28500 Miles Rider Mileage: Many Miles
CBT: PASSED Theory: PASSED Test: PASSED
Past-CG125 Present - Yamaha XJ600N Future - WHO KNOWS?
Rhys
PostPosted: 02:41 - 12 Feb 2007    Post subject: Reply with quote
im getting adobe audition to see if that'll do it, working out how may prove a mission as with usual adobe software(even though usually good in the end). for the video editing ive been using cyberlink powerdirector, which seems to only be able to change the audio track volume at set times. oh and also had a go with goldwave but just got some wierd star trek/star wars type engine noise!
...maybe it just needs hours of knowing what to do spending on it
Trip
PostPosted: 02:50 - 12 Feb 2007    Post subject: Reply with quote
The only real way to get rid of wind noise is to not record it...
A slightly more helpful answer would be to use a Hi - pass filter, however i guess that would cut out most of your engine noise with it.
You can have a play with some EQ aswell to try and get the optimum compromise between Wind and Engine.
Im asuming it was a bulletcam with built in mic or something similar?
Next time try using a wind shield over the mic....
Rob
PostPosted: 11:51 - 12 Feb 2007    Post subject: Reply with quote
If you have a mac, you can use 'Soundtrack Pro' as it has a really good audio analysis graph and you can easily isolate the annoying frequencies and remove them.
Although the main problem will be that wind noise can cover quite a large frequency range so you might end up losing other stuff too!
As was suggested above, perhaps just try pulling those frequencies down with eq.
Rob
Love is 1050cc Smile
Trip
PostPosted: 01:24 - 17 Feb 2007    Post subject: Reply with quote
Fixed it Rhys?
Rhys
PostPosted: 01:14 - 18 Feb 2007    Post subject: Reply with quote
just realised you'd posted replies, ive tried what you've said. Havent got round to spending lots of time on it due to work, but quickly played around with the settings that you mentioned and noticed a reduction, just needs abit of fine tuning as it did take out abit of the wanted sound. Also some time and patience!
thanks for the help anyway Thumbs Up
Rhys
Trip
PostPosted: 01:16 - 18 Feb 2007    Post subject: Reply with quote
What formats the sound in mate?
If you can send it to me ill have a crack myself...
The last post was made 19 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 58.93 Kb
