| california_rookie |
 california_rookie World Chat Champion
| T1z3R |
 T1z3R World Chat Champion
| california_rookie |
 Posted: 11:04 - 12 Feb 2007 Post subject: |
| Matt06 |
 Matt06 World Chat Champion
 Posted: 11:14 - 12 Feb 2007 Post subject: |
Another thing... Most games that dont have a Widescreen resolution in-game can be altered to force Widescreen using a command on the shortcut . ____________________ Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09 |
| california_rookie |
 Posted: 19:32 - 12 Feb 2007 Post subject: |
| Matt06 |
 Posted: 22:08 - 12 Feb 2007 Post subject: |
Well, for the game Battlefiled 2142 which doesnt have Widescreen in-game... The command is +widescreen 1 +szx 1680 +szy 1050 added on the end of the shortcut.  ____________________ Current: MT-10, Bandit, Grom, GPZ500
| california_rookie |
 Posted: 01:39 - 13 Feb 2007 Post subject: |
Excellent. My max resolution will be 1440/900 so I'm assuming I'll swap your numbers for mine when I add it to the shortcut?
How well does the game work after this? Does the GUI format to fit the new screen layout or do they just kinda stay towards the center of the screen as if it were still 4:3?
Also, if anyone knows how use this trick to make CS:S automatically limit itsself to 25fps, I'd appreciate it. I used to use this on HL1 but either it's changed or I'm remembering it wrong.
"+exec fps_max 25" ____________________ https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion |
| Matt06 |
 Posted: 12:54 - 13 Feb 2007 Post subject: |
Yeah, you should be able to just swap the numbers around and it should still work. However, it might not work for all games i have only used this command thing on Battlefield 2142. Dont see why it wouldnt though.
The games should work fine after using the command. Sometimes there are small problems with things looking a bit stretched or something but generally its all good.
As for CS:S, you can limit the framerate with max_fps 25 in-game using the console. If you activate the console under controls/advanced/Enable Dev Console you can use the ` key to enter it. Its the key next to the number 1 key and above the tab key. When the console is up just type in max_fps 25 or whatever you want to set it too. I think that should work. ____________________ Current: MT-10, Bandit, Grom, GPZ500
| Phil_C |
 Phil_C Nova Slayer
 Posted: 15:10 - 14 Feb 2007 Post subject: |
It doesn't look like you're having any issues, but in case someone else is reading this and cannot force widescreen at the proper native resolution (1440x900 or whatever) they should try Powerstrip, available at download.com. Make sure you read the instructions, as it can be quite unfriendly to use for the non-technical. This will make sure you can use your screen to its fullest potential
Btw I've played World Of Warcraft on my 40" LCD. Woooow thats just insane. The wife wasn't impressed tho, she was missing yet another repeat. |
| california_rookie |
| Phil_C |
 Phil_C Nova Slayer
| Matt06 |
 Posted: 19:09 - 15 Feb 2007 Post subject: |
Hmmm, If you havent managed to find a solution for Max_fps, i might have one. If it works .
Open you're hard drive and find the steam folder. It should be something like C:/Program Files/Steam. Then in the steam folder find Steam/steamapps/yoursteamname/counter-strike source/cstrike/cfg. In this folder there should be a file called "config.cfg". Open this with notepad if it asks and then inside there at the end of all the existing stuff written, add you're max fps code. So for 25 frames, add max_fps 25 at the end of the the file. If I am right it should set that automatically everytime you load up. If you ever want to change it just go back into the file and change it or get rid.
Hope this helps . It should work . ____________________ Current: MT-10, Bandit, Grom, GPZ500
The last post was made 19 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
