nsr break lever
mansong001
PostPosted: 11:07 - 17 Feb 2007    Post subject: nsr break lever Reply with quote
hi,
im trying to remove my right break lever as it snapped through a fall.there is a nut underneath and a screw on top(philips)however,what do i need to remove the nut?
dave madden
Welshd1k
PostPosted: 12:20 - 17 Feb 2007    Post subject: Reply with quote
just get a small spanner ad un do it Thumbs Up then unscrew the screw Very Happy
Dalemac
PostPosted: 13:28 - 17 Feb 2007    Post subject: Reply with quote
yup, dead easy, should take all of 3 mins to replace it.
and be sure to lube the new leaver up abit (the same as you see when you take the old one off. I used a bit of vaseline and it worked fine Thumbs Up
YBR125 -> GPZ500S -> SL1000
alains
PostPosted: 15:51 - 17 Feb 2007    Post subject: Reply with quote
if you've got problem , you can dismount the holder
shaun_04
PostPosted: 17:27 - 17 Feb 2007    Post subject: Reply with quote
In the case of my levers: Use the screwdriver to hold the bolt still, and use a spanner/socket to undo the nut first, as you will see that the bolt actually screws into the lever housing aswell.
but in terms of the original question:
Is that a joke?
Dalemac
PostPosted: 01:24 - 18 Feb 2007    Post subject: Reply with quote
Is that a joke?
I believe so Wink
Jamie S
PostPosted: 01:42 - 18 Feb 2007    Post subject: Re: nsr break lever Reply with quote
Try using hammer it should work fine ! Thumbs Up ! Laughing Laughing Laughing
no really do you not know how to do that ? lol
The last post was made 19 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.79 - MySQL Queries: 15 - Page Size: 51.7 Kb
