rusty NEW chain
befdelta7
PostPosted: 23:20 - 17 Feb 2007    Post subject: rusty NEW chain Reply with quote
hi,
could someone please tell me why my chain is rusty when its only 3weeks old?!
it was already oiled when i got it out the box, i greased it with some universal grease when i fitted it while the bike was off the floor and i have been putting WD40 on it every now and again.
even the couple of links i had to have cut off are just as rusty and i havent even bothered greasing that, was left in the garden untouched to die.
so why is the chain just as rusty as the few links that have been left to perish when the chain has been looked after??
cheers,
james
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
instigator
PostPosted: 23:22 - 17 Feb 2007    Post subject: Reply with quote
Don't use wd40 on it.
I presume it is kept in a damp environment?
Get some decent chain lube/wax.
Finglonga
PostPosted: 23:30 - 17 Feb 2007    Post subject: Reply with quote
As above..WD40 will wash off the grease and do more damage than good. Get a good quality chain lube and give it a coating. The side plates will go rusty if not lubed but it will only be surface rust.
Andy Sez....
F.Y.Y.F.F.
befdelta7
PostPosted: 23:31 - 17 Feb 2007    Post subject: Reply with quote
hi,
i keep the bike in the back garden.
the old chain that came off it wasnt rusty, was just had black and sticky shite on it.
befdelta7
PostPosted: 23:42 - 17 Feb 2007    Post subject: Reply with quote
thats exactly where the majority of the rust is!
how would i go about getting rid of that? a wire brush maybe?
Jamie S
PostPosted: 23:47 - 17 Feb 2007    Post subject: Reply with quote
a wire brush will be the best thing. an ally wire brush would be better but any type will be ok.
hope this help
jamie stokes
Dalemac
PostPosted: 00:42 - 18 Feb 2007    Post subject: Reply with quote
sounds to me like the old chain didnt even need replacing.
Althought that "black and sticky shite" is simply your grease and dirt off the road mixed together, which grinds away at the chain and sprockets. too much of this and you will have to buy a whole new chain and sprocket set Thumbs Down
To avoid this, simply clean the chain, using WD40 and a toothbrush (preferably your little sisters) (lol)Thumbs Down until all the black goo is gone, and clean the sprockets with this too, getting rid of all the crap.
Then apply loads of grease to lubricate the chain (such as castrol chain wax)
Do this every week and it can prolong the life of your chan and sprockets.
Be ready with at least a whole newspaper under the chain, to catch the lovely dirty crap, and also dont let the WD40 go onto your tyres, as it will harden the rubber, (which is bad of corse)
And remember, as with everything in life, you get what you pay for.
Good luck cleaning that dude.
Dale
YBR125 -> GPZ500S -> SL1000
befdelta7
PostPosted: 01:45 - 18 Feb 2007    Post subject: Reply with quote
cheers for you info Dale_Mckeown
very helpful Thumbs Up for you!!
Jamie S This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
Dalemac
PostPosted: 02:29 - 18 Feb 2007    Post subject: Reply with quote
what jamie?
befdelta7
PostPosted: 11:04 - 18 Feb 2007    Post subject: Reply with quote
whats that got to do with the post jamie??
Zimbo
PostPosted: 11:22 - 18 Feb 2007    Post subject: Reply with quote
Don't use WD40 to lubricate anything, it isn't a lubricant, it's a solvent and will disolve and wash off any lube that's ohere in the first place.
element
PostPosted: 21:39 - 18 Feb 2007    Post subject: Reply with quote
I wouldnt buy castrol chain wax again to be honest. I thought it was crap. It just gets pushed to areas that have no wear leaving the areas with the most stress bare and its a bit overpriced at £6 a tin! Not only that its an absolute bitch to clean off...
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
Finglonga
PostPosted: 21:59 - 18 Feb 2007    Post subject: Reply with quote
Always lube after a ride not before as the hot/warm chain will let the lube run into the links. If yu do it when the chain is cold it will just sit on top and fly off when you use it.
Andy Sez....
F.Y.Y.F.F.
slj23
PostPosted: 22:54 - 18 Feb 2007    Post subject: Reply with quote
(wouldnt buy castrol chain wax again to be honest. I thought it was crap. It just gets pushed to areas that have no wear leaving the areas with the most stress bare and its a bit overpriced at £6 a tin! Not only that its an absolute bitch to clean off... ) i just cleaned and lubricated my chain using castrol chain wax,seem's ok definate improvment,but if this product isn,t that good as you say could you recommend one that is .p.s how do you do the little boxes with someone elses comments in them i'm a newby and couldn't figure it out.
'isn't it enough to see that a garden is beautiful without having to beleif that there are fairies at the bottom of it too?'
Dalemac
PostPosted: 23:02 - 18 Feb 2007    Post subject: Reply with quote
you press the quote botton, at the top hand right of the post.
then delete any text you dont want/ dont need.
element
PostPosted: 23:17 - 18 Feb 2007    Post subject: Reply with quote
slj23 wrote:
i just cleaned and lubricated my chain using castrol chain wax,seem's ok definate improvment,but if this product isn,t that good as you say could you recommend one that is...
personally id use anything that isnt wax based. Im using silicon based lube at the minute and it seems to work better for me.
HermanTheShee...
PostPosted: 23:31 - 18 Feb 2007    Post subject: Reply with quote
Each to their own, but I have used Castrol chain wax for a year now, and I find it works very well. I clean the chain once a week then put the wax on. It goes transparent so the chain looks very clean and it doesn't "fling".
You should read up a bit on the different methods and you will find something that suits you (in terms of how much time you want to spend on it and how dirty you want to get) Smile Thumbs Up
2004 Suzuki GS500F > 2006 Suzuki SV650S
My real name isn't Herman
Zimbo
PostPosted: 23:38 - 18 Feb 2007    Post subject: Reply with quote
The lube that came out best after tests by some of the magazines was Wurth Dry Lube, you can get in on ebay.
PostPosted: 23:42 - 18 Feb 2007    Post subject: Reply with quote
I'd use a scottoiler or a Loobman.
Chain wax and lube seems to attract dirt and make a grinding paste which knackers chains very easily.
Keep the chain clean and lube it with engine oil (via scottoiler or Loobman or similar) and It'll last a lot longer.
And don't say Scottoilers are too expensive, cos a Loobman is £20 or something.
Costs /at least/ £20 for a new chain...
wal750
PostPosted: 00:25 - 19 Feb 2007    Post subject: Reply with quote
Never use WD 40 on a chain, it can damage the o rings / x rings
goatrider
PostPosted: 04:47 - 19 Feb 2007    Post subject: Reply with quote
I agree with MarJay.
Haven't got a scottoiler coz they are a bit expensive (wasn't aware of the Loobman so I'll have a look for one of those - thanks MarJay Thumbs Up ) but I find that applying engine oil sparingly with a paint brush on a clean chain is better than any of the spray on lubes I have ever tried (castrol, wurth etc). Just make sure you work it into the chain well (when the chain is warm / hot is definately best) to avoid it flinging off as soon as you ride. The last thing you want is lube of any kind all over your back tyre for obvious reasons.
I only use standard HD chains with no o-rings or x-rings so I use gunk and a tooth brush to clean the chain before I oil it - might not be a good plan to use gunk on x/o-ring chains though as I dont know how the gunk would affect the rubber.
Clean and lube once a week at least and all should be good.
Goat Wink
Honda NS125R 1987, Suzuki GS500EW 1998, Honda CB750F2N RC42 1992
"I dont give a shit who your dad is......quit walking on the water while I'm fishing......."
SoND
PostPosted: 05:12 - 19 Feb 2007    Post subject: Reply with quote
Myth.
Marci
PostPosted: 11:02 - 19 Feb 2007    Post subject: Reply with quote
3-in-1 chain oil (black aerosol can) with PTFE... halfords, about £3 a can... runs into every crack then coats everything with a light white sheen of silicon/teflon... works fine for me, takes about 20 seconds to apply a good coat (joys of a center stand) and generally needs doing once a month or so... also use it to give all stand springs etc a good covering.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
befdelta7
PostPosted: 11:56 - 19 Feb 2007    Post subject: Reply with quote
Thumbs Up Marci thanks for that info, also thank you all who replyed for your info and input Thumbs Up for you lot too!
The last post was made 19 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 128.44 Kb
