Found 45/40W NSR Bulbs for 85p!!!!
Lee
PostPosted: 12:34 - 21 Aug 2003    Post subject: Found 45/40W NSR Bulbs for 85p!!!! Reply with quote
Hi all.
I was searching BCF for old articles on upgrading the late-shape NSR's headlight bulbs for brighter ones, and everyone was saying that the maximum they could find was 35W in the Bosch BA20D fitting. Well if it is any help to anybody i've found an online retailer which sells 45/40W BA20D bulbs for just 85p!! (bedspeed is about £5/£6 per bulb).
Click here to see the site (normalec.com) Note the BA20D bulbs are more than half way down the page, just press CTRL and F and type BA20D then hit 'Find Next'.
Hope this helps someone.
Lee
Scotty
Scooter Boi
PostPosted: 13:05 - 21 Aug 2003    Post subject: Reply with quote
But wouldnt changing the bulbs to a brighter one actually make the light dimmer, as the voltage gonig through would still be 35w. and being as the filement will be different it will actually be dimmer. ??
Regards
Scott
True Blue
PostPosted: 13:10 - 21 Aug 2003    Post subject: Reply with quote
No, thats not how a bulb works. The VOLTAGE going 'through' is 12v regardless of the WATTAGE of the bulb. The higher wattage of the new bulb will draw a larger current through them. Providing this is not higher than the rating of the fuse and more importantly , the cable, then it will be brighter.
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
Milo
PostPosted: 13:23 - 21 Aug 2003    Post subject: Reply with quote
Damn Honda and they're Bosch light fittings on the NSR!
Anyone ever tried to navigate a foggy nightime country lane with standard NSR lights?
45/40 sounds a bit high for an NSR-you might wanna check the fuse can take it and if the standard fuse can't then go for lower wattage-you don't want to knacker the wiring or melt the headlight "glass"
isn't standard 25/25? i think i upped mine to 35/30, which is the highest M&P did at the time.
Lee
PostPosted: 13:25 - 21 Aug 2003    Post subject: Reply with quote
Nope as True Blue said, thats not how it works. The standard NSR bulbs are 25w, but alot of people fit 35w bulbs because they're quite a bit brighter. Because the BA20D is an obsolete fitting they are quite hard to find, and up until now the only thing we could find were 35w bulbs from bedspeed for £6.
m i k e
tried it once with a cg! Razz Laughing
Bom Chicka WAHHH WAHHHHHHH!
Milo
PostPosted: 13:33 - 21 Aug 2003    Post subject: Reply with quote
yeah, it got better when i got a GPz with a normal headlight but still it's not something to be enjoyed!
wish i has some NV goggles!
m i k e
PostPosted: 13:34 - 21 Aug 2003    Post subject: Reply with quote
or maybe.........some proper lights on your bike? Razz
True Blue
PostPosted: 13:35 - 21 Aug 2003    Post subject: Reply with quote
Lee, have you tried them yet? Do you know what rating the cable has?
Demonic69
The Pink Rhino
PostPosted: 13:36 - 21 Aug 2003    Post subject: Reply with quote
Lee, are you and TrueBlue the same person?? Wink
Back on a Blade. Just feels so right.
True Blue
PostPosted: 13:38 - 21 Aug 2003    Post subject: Reply with quote
Milo
PostPosted: 14:26 - 21 Aug 2003    Post subject: Reply with quote
the more light the more reflection, so NV goggles would be much clearer!
i ride an XJ900, so lights aren't a problem anymore Razz
m i k e
PostPosted: 14:27 - 21 Aug 2003    Post subject: Reply with quote
wouldn't it be the less light the clearer the goggles? Confused Razz
Milo
PostPosted: 14:47 - 21 Aug 2003    Post subject: Reply with quote
i was comparing havingmore/better lights t NV goggles. visable light doesn't affect them, IR/heat.
I've seen a review of a diesal crosser for military use with a built in IR light source insteat...very nice!
Lee
PostPosted: 15:48 - 21 Aug 2003    Post subject: Reply with quote
Have not tried them yet m8, i'm going to give them a ring and order some. On nsr125.de forums there are a few threads where people have fitted 55/50w without problems, so I dont think these should be.
True Blue
PostPosted: 16:52 - 21 Aug 2003    Post subject: Reply with quote
might get myself some then Smile
TGE125NSR This post is not being displayed because the poster is banned. Unhide this post / all posts.
Zimma
Wheelie Junkie
PostPosted: 18:03 - 21 Aug 2003    Post subject: Reply with quote
TGE - Your low beam filaments have blown, replace the headlight bulbs. The low beam should come one with the rh switch all the way over to the left and the high beam button off.
-Zimma
Scotty
Scooter Boi
PostPosted: 18:53 - 21 Aug 2003    Post subject: Reply with quote
Any one wanna change his Custom Name to "Walking Disaster"
Regards
Scott
Lee
PostPosted: 22:24 - 21 Aug 2003    Post subject: Reply with quote
TGE125NSR wrote:
FFS! Ive just put all the panels back on!
I only had one bulb working in the first place i thought it was strange, but they both work with full beam on!
I have one spare bulb somewhere.
Mandatory TGE post saying 'I've broken something' per thread now satisfied.
There is a gap of 3 years, 88 days between these two posts...
kristianc4
PostPosted: 12:00 - 17 Nov 2006    Post subject: Where? Reply with quote
where are these 85p BA20D bulbs, because i can't find them. reply if you know or found where they are.
cheers
K Chambers
Gazdaman
I did a trackday!!!
PostPosted: 13:03 - 17 Nov 2006    Post subject: Reply with quote
Might be better off not posting in a thread that's 3 years old...
I suggest you use google if the link posted at the top is dead..
Gaz
The last post was made 19 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.54 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 130.08 Kb
