Whats wrong with VFR750s
Itchy
PostPosted: 09:19 - 01 Mar 2007    Post subject: Whats wrong with VFR750s Reply with quote
Seen a nice one ('95) parked next to an NC30 in a dealers , priced 200 more , 29K on the clocks ,full history T+T, tempted
what are their vices other than the usual honda rectifyer problems? , and an old man image problem and probably extortionate insurance.
any thoughts?
Ta
PostPosted: 09:49 - 01 Mar 2007    Post subject: Re: Whats wrong with VFR750s Reply with quote
any thoughts?
Ta
The old man image problem is because they weigh more than 200kg dry and only make about 95bhp.
That said, a well looked after example will be comfy, reliable, stable and quick enough for you. The main issue is that it is seven years old. Insurance will probably be about the same or perhaps less than for the '30.
BanditBitch
PostPosted: 09:51 - 01 Mar 2007    Post subject: Reply with quote
My other half has one at the moment and he loves it, I'll ask him for the low down when he gets in.
Lol.....I'll tell him that, that'll amuse him Very Happy
killa
Won't Shut Up
PostPosted: 09:56 - 01 Mar 2007    Post subject: Reply with quote
A friend of mine has a stage one tune and a full remus system.
Although it sounds lovely, it does just over a 13 sec quarter mile Surprised
PostPosted: 13:47 - 01 Mar 2007    Post subject: Reply with quote
A few of them have been dispatched on so look for marks from throw over panniers and the like.
They are solid engines though.
Itchy
PostPosted: 13:56 - 01 Mar 2007    Post subject: Re: Whats wrong with VFR750s Reply with quote
well my NTV650 weighs 215 wet , has 53bhp and I can waste many riders on it , give me double the bhp (nearly) , twin brakes so I can brake later, and 2 more cylinders, and a chain drive , and fairing and I think I'll waste a few riders yet,
Itchy
PostPosted: 14:43 - 01 Mar 2007    Post subject: Reply with quote
erm can you give some other 1/4 mile times to make me see if this is impressive or not? , net searches say subaru imprezas get 13.6
some quick searching got:
2004 times from
https://www.sportrider.com/features/146_0406_2004_literbikes_strip/
all seem to be around 9.9 seconds with the blade the slowest(!?)
but what against my primary opposition? 600SS, 636s , CBRs , hornets fazers , SVs etc?
PostPosted: 14:45 - 01 Mar 2007    Post subject: Reply with quote
A stock ZZR1400 will dip into the 9 secs mark with a decent rider.
map
Mr Calendar
PostPosted: 16:01 - 01 Mar 2007    Post subject: Re: Whats wrong with VFR750s Reply with quote
Itchy wrote:
Whats wrong with VFR750s...
any thoughts?
In a nutshell - nowt.
That's nothing, if you're posh.
The VFR750 was the benchmark sports tourer. The only thing better was the VFR800. Even now it hasn't slipped that much against newer machinery.
Insurance isn't that much of a deal breaker. As with any bike depends on location and storage. Alarm, approved type, helps too (again, same with any bike).
IMO old man image not a problem on the road. I wasn't aware it had one until reading posts on here. Now BMWs, that's a different pipe and slippers story Very Happy. In fact I'd rather have the big VFR with its ability to do loadsa miles and then be able to take the panniers off and play sporty.
HTH Thumbs Up
killa
Won't Shut Up
PostPosted: 16:47 - 01 Mar 2007    Post subject: Reply with quote
I was just basing the time against my Kwak, 13.something everytime is pretty slow.
But then round twisties the VFR can keep up Thumbs Up
craigs23
Mr Muscle
PostPosted: 19:24 - 01 Mar 2007    Post subject: Reply with quote
Nah, the 750 hasn't been beaten by its later incarnations.
Anything wrong with it?
Erm, apparently could do with a bigger engine to compete with modern day tackle. Could be a little lighter (main reason I don't own one). V4's a bit fiddly to work on.
Itchy
PostPosted: 20:51 - 01 Mar 2007    Post subject: Reply with quote
I do wonder why big VFRs are so heavy , the VFR800I has an alley frame and is still heavier than the 750 , sure the single swing arm adds weight but the Bros 650 has a single swinger and is a helluva lot lighter.
I'm used to weight though I ridden plenty of rats.
owdamer
PostPosted: 22:33 - 01 Mar 2007    Post subject: Reply with quote
Vfrs are probably heavy because they are over engineered.
They're built to a high quality and they are built to last.
I ran one for 3 years, Not the most exciting bike in the world, but it would sit at 100+ all day long, it did 45mpg, will do nearly 200 miles on a tank and could hit 150 if needed.
Its not a sports bike, but then it was never meant to be.
I'd have another tomorrow.
map
Mr Calendar
PostPosted: 12:39 - 02 Mar 2007    Post subject: Reply with quote
craigs23 wrote:
...V4's a bit fiddly to work on.
Very Happy Where's the understatement rating when you need it Wink
Forgot about that bit.
I found the actual engine isn't that bad. It's all the faff about removing the plastics, without breaking it, and what to loosen so you can get at other bits (the radiator is a good one).
Itchy
PostPosted: 14:40 - 02 Mar 2007    Post subject: Reply with quote
I had a look at some impartial stats says 219 kilos dry! , blimey thats more than my NTV650,
craigs23
Mr Muscle
PostPosted: 15:35 - 02 Mar 2007    Post subject: Reply with quote
I don't actually mind working on my 1/2 scale version - everything just nicely fits together - like everything's been designed around eachother rather than just bolted on. Fitting carbs, exhausts, etc can be tricky though, two sets of heads to set up/maintain - can understand why people might be a little put off, but the things are so mechanically reliable that they seem to shrug off everyday abuse.
The weight of the thing put me off a little as I'm not the largest of riders, I have heard they carry their weight very well though. Not the flightiest/quickest turning of bikes, but as mentioned, that's missing the point of them.
I'd have one once I get tired/old/too fat for half-sized sports reps.
Itchy
PostPosted: 14:33 - 03 Mar 2007    Post subject: VFR750 updated with pics Reply with quote
UPDATED with pics
Went to have a look at a VFR750 today , as the original I looked at had been swiped
and had long gone , grr
However lucky enough there was another one nearby, in Silver I'd like red but what the
hey?
here are some pics turned out to be a CAT D the body work was perfect though the frame was unbent ,
, the forks were straight if a little pitted at the top (not on the stanchions) , and the brakes were ok , with
plenty of meat left on the pads tyres etc, with just rust on bolts were and there,
however looking closer the pipe work looked like the pictures below,
Has Scotoiler , 1MT+T , 24K on clocks, R&Gs , and imobi + alarm
worth £1600?, or wayy too cheap and therefore asking for trouble (pre haggle btw)
PostPosted: 14:40 - 03 Mar 2007    Post subject: Reply with quote
https://www.v-four.freeserve.co.uk/vfr750-3.htm
From that it seems that Bike magazine tested it at 11.6 seconds @ 117mph.
owdamer
PostPosted: 22:50 - 06 Mar 2007    Post subject: Reply with quote
If the rear downpipes rot then its an engine out job to replace em so make sure they're ok. rear shocks have been known to expire at 20k so look at that as well.
gmanxiii
PostPosted: 00:21 - 07 Mar 2007    Post subject: Reply with quote
i think you should get that 30 you was watching on ebay.... Wink
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
Itchy
PostPosted: 09:20 - 07 Mar 2007    Post subject: Reply with quote
being shilled on it, not buying it , considering just repairing the NTV for tour if I can fix it, , then getting something else later on.
say don't forget to add yourself to the BCF spills list.
craigs23
Mr Muscle
PostPosted: 09:42 - 07 Mar 2007    Post subject: Reply with quote
You don't need to drop the engine to change the exhaust on an NC30, is the 750 much different??
Itchy
PostPosted: 13:56 - 07 Mar 2007    Post subject: Reply with quote
the problem isn't so much changing them but the cost ! , a new stainless system for a VFR750 is close to £420 , and that doesn't include gaskets , and the damage I will do to my furniture when something doesn't go right.
Zen Dog
PostPosted: 14:16 - 07 Mar 2007    Post subject: Reply with quote
Problems with the VFR -
1 - Rectifier (as noted) - The replacement i got from David Silvers is still working 2 years later though.
2 - Exhaust - Mine is rustier that the one in your pic itchy, and isn't blowing yet, but when it goes it IS gonna cost big time.
3 - Brakes arent up to modern standards, but in good nick, they do the job just fine. I've been told you can replace the fork legs and calipers with firestorm ones, but i haven't tried that yet.
4 - Can be a bit of a pain to work on, due to the complexity of the engine and exhaust setup, and the bodywork is very solid but a pain to remove.
5 - Speedo - Runs off a sensor near the front sprocket. Mine stopped working for a while, but i gave it a bit of a clean and its been fine again for ages. But i priced up the sensor, think it was about £70 Shocked . Parts prices can definately be a bit steep.
Zen Dog
I always thought insurance was pretty cheap, certainly not in sportsbike territory.
killa
Won't Shut Up
PostPosted: 09:51 - 08 Mar 2007    Post subject: Reply with quote
It wont do that, and the VFR in question was actually the old 800.
You'd have to scream that thing to get inside 11 seconds.
The last post was made 19 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 143.19 Kb
