UPDATE PISTON BLOWN HELP..... * PICS INCLUDED *
Strapstah
PostPosted: 13:51 - 04 Mar 2007    Post subject: UPDATE PISTON BLOWN HELP..... * PICS INCLUDED * Reply with quote
Ok, as many of u know i had a recent problem with my bike( Aprilia mx 50 03' Supermoto).... I finally managed to take the bore out and the pics are shocking....
Piston
https://i15.tinypic.com/3z1bh3s.jpg
Head
https://i7.tinypic.com/3zauath.jpg
Now, i need your help geezers, is there a chance there are no bits of metal in the engine?. Because it looks like it all got squashed at the top looking at the pic. Confused
Also i have one problem i cant take my exhuast off, theres one fukin bolt that takes allen key but the allen key it takes i put it inside tried twisting it to the left and the allen key broke!. Its an impossible bolt. someone help me think of a way i could take the bolt off, so i can take the barrel off to see if i need a new barrel and piston... heres the pics of the exhaust bolt.. Sad
https://i8.tinypic.com/4bz10mc.jpg
https://i14.tinypic.com/47i4pit.jpg
Please help thanks, strap-on.
Easy FAM!
Welshd1k
PostPosted: 14:01 - 04 Mar 2007    Post subject: Reply with quote
the allan key bold it saff all jusy sits ont he rubber if you loosen it all of it will just pull away Wink
and id lik to see what your bore is like
Strapstah
PostPosted: 14:04 - 04 Mar 2007    Post subject: Reply with quote
wait could u explain better please. i didnt understand what you said.... im sorry but i dont understand
"the allan key bold it saff all jusy sits ont he rubber"
wdf? lol, nah seriously what did u say im just waiting for a answer so i can do it now!!!.
Also u see my spark plug... do you lot think its the correct colour?. I wanna know why this happened.
Easy FAM!
rpg
PostPosted: 14:34 - 04 Mar 2007    Post subject: Reply with quote
it looks as if you have been running very weak which has caused a hole in the top of the piston. Did you upjet the carb when you put on the polini? Either that or an air leak making the engine run excessively lean.
rpg
PostPosted: 14:35 - 04 Mar 2007    Post subject: Reply with quote
Welshd1k
PostPosted: 14:48 - 04 Mar 2007    Post subject: Reply with quote
the rubber thing is just a rubber mount it just pulls away(well on my '04 it did) if not id say mole grips or drill it out Very Happy
Resurrection
Ballast Boy
PostPosted: 14:50 - 04 Mar 2007    Post subject: Reply with quote
If you have a socket abit bigger bash it on with a hammer then ratchet it off!
Res
ZX9r
Welshd1k
PostPosted: 14:52 - 04 Mar 2007    Post subject: Reply with quote
and the tubber block is bolted to the frame not the whole thing it splits in two take all the other connectors of the can then twist it around and it will pull of Very Happy
Strapstah
PostPosted: 14:55 - 04 Mar 2007    Post subject: Reply with quote
im sorry i dont understand how i could twist the exhaust while the end is stuck in the barrel..., i cant twist nothing because its still in the barrel, i need to take the bolt off!
Easy FAM!
Welshd1k
PostPosted: 15:03 - 04 Mar 2007    Post subject: Reply with quote
springs off yes ?
end can of yes?
well grab hold of it and yank it forwards to get it out of the barrel then it will pull away (mine does) the allen key doent turn
Strapstah
PostPosted: 15:06 - 04 Mar 2007    Post subject: Reply with quote
so how do i put it back?.
Easy FAM!
Welshd1k
PostPosted: 15:46 - 04 Mar 2007    Post subject: Reply with quote
the same way as you took it of there right sods
btw did you get it off?
Strapstah
PostPosted: 16:58 - 04 Mar 2007    Post subject: Reply with quote
Ok, heres the latest, i managed to take exhaust of. Ty
Heres pics of the top where the head barrel was. You can see little bits of metal.
https://i13.tinypic.com/2i74vg6.jpg
heres the inside of the barrel.
https://i13.tinypic.com/2h338xv.jpg
https://i18.tinypic.com/4ca9wfq.jpg
Ok, now what should i do... aka, what do you guys think i need, this is what i think i need:
A new bore kit
Engine cleanup for little metal bits.
Please someone tell me what i need please?. Also if i only need a piston because the barrel wall looks ok to me.
Thank you very much.
Easy FAM!
Jazoli
PostPosted: 17:29 - 04 Mar 2007    Post subject: Reply with quote
Unlucky, that looks a mess, did that a few times to my RD125LC many years ago! That had a 190cc kit and kept blowing up.
You're going to have to split the crankcases and get all the bits of melted piston out, if you stick a new piston in without doing this then run the motor it will go bang again very shortly, barrel looks ok but hard to tell by the pics, you may get away with just a new piston.
Smile
https://www.casa1011.com Quality accomodation in Spain, shameless plug Very Happy
Bike:Speed Triple
Finglonga
PostPosted: 17:52 - 04 Mar 2007    Post subject: Reply with quote
Strapstah, Keep all the receipts and photos as Asda now say their fuel was contaminated with silicone, you may get compensation if the station where you got the fuel is contaminated.
Morrisons withdrew unleaded petrol from sale at 41 of its filling stations on Friday, including its Norwich store in Albion Way, which was supplied by the Essex depot. Superstore Tesco also emptied unleaded fuel tanks at forecourts across the region after tests showed they had been contaminated.
On Sunday Tesco and Asda were working to replace unleaded at each forecourts. The supermarkets are promising to pay compensation to customers whose cars have suffered damage.
Andy Sez....
F.Y.Y.F.F.
Welshd1k
PostPosted: 17:54 - 04 Mar 2007    Post subject: Reply with quote
ohh that looks nasty bore is ok
id split the bottom end and have all new bearings while its open and a new pistona nd rings and youve got a brand new engine looks a tad nasty mate
Strapstah
PostPosted: 20:16 - 04 Mar 2007    Post subject: Reply with quote
does that coolant colour look nice?.... is it ment to be dark greenish.
Also, i dont have a recipt of the petrol but im 100% sure im on there cctv on my bike... so what should it do now? who do i go to???.
Easy FAM!
Finglonga
PostPosted: 20:59 - 04 Mar 2007    Post subject: Reply with quote
I would go back to the place you purchased the fuel from and ask them if they have had any reports of problems with their stock of fuel. It may be worth asking the person running the pumps and then the store manager, dont take your first reply as gospel. If there has been a problem you will need to speak to the manager to tell him what has happened to your bike.
Andy Sez....
F.Y.Y.F.F.
Matt2301
PostPosted: 22:50 - 18 Apr 2007    Post subject: Reply with quote
Hey Strap,
I don't know if you still frequent this forum, but I have a Minarelli AM6 engine, as used in the Aprilia RX50.
I'd be pretty willing to bet that it's compatible with the MX50, and it might be more economical to buy it then to pay a mechanic to strip down your existing engine.
If you still need an engine and are interested, PM me:)
Matt2301
Hey Strap,
The last post was made 18 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 108.17 Kb
