What should I look for on buying a bike?
loveday
PostPosted: 11:11 - 06 Mar 2007    Post subject: What should I look for on buying a bike? Reply with quote
About to go and look at a bike this evening and hoping to take a friend along who knows his stuff. But... on the off chance he can't make it what sort of things should I be looking for? i.e the telltale signs of it bein slid down the road etc.
Any help on this would be appreciated. Cheers.
ps its an R6 by the way
Jamie S
PostPosted: 12:46 - 06 Mar 2007    Post subject: Re: What should I look for on buying a bike? Reply with quote
Bent leavers,
Handle bar grips having the ends missing,
Scraped exhaust cans,
Scratches on faring that look like long thin ones,
Bent handle bars,
Bent foot rests,
If they have rubber, foot rest rubbers being damaged.
^All of the above could mean it has been slid.^
But a few of them could of just happened if it was dropped In your garage, fallen of center stand ect.
Kyzia
PostPosted: 13:04 - 06 Mar 2007    Post subject: Reply with quote
Unusual gaps between fairing panels may indicate that the bracketry that holds them on has been bent up previously.
2002 Honda Hornet 600 F/S
Finglonga
PostPosted: 13:32 - 06 Mar 2007    Post subject: Reply with quote
Make sure the engine is COLD when you get there to see if it has any starting issues. Could help letting you know if the battery is duff BUT they could have had it on charge all day and took it off before you turned up.
Andy Sez....
F.Y.Y.F.F.
Jamie S
PostPosted: 14:26 - 06 Mar 2007    Post subject: Reply with quote
Just to add to that , before starting it up if you can see the battery ( usaly under the seat and is easy to get to you just use the key) check thats cold to, if its warm then it will have been on charge before you got there and would probably mean its a gonna.
also yes make shure its started from cold .
cheers
jamie stokes.
Itchy
PostPosted: 14:34 - 06 Mar 2007    Post subject: Reply with quote
lock stops on the headstock should be intact , not snapped or bendy,
general scratches,
for miles , look at general condition
older well used bikes have fork leg markings thatwon't polish out.
mismatched bolts, ie some are more corroded than others esp on fairings, = replacement pattern part?
bar ends , bars , cans etc are unreliable as they can be way easily replaced.
loveday
PostPosted: 14:46 - 06 Mar 2007    Post subject: Reply with quote
Cheers fellas Thumbs Up
Speedy3
PostPosted: 16:19 - 06 Mar 2007    Post subject: Reply with quote
If its an R6, i think i remember someone posting about it slipping out of 2nd/3rd into neutral abit? Anyone shed some light?
TomR6
PostPosted: 16:28 - 06 Mar 2007    Post subject: Reply with quote
Yeah the 98-02 models slip in and out of 2nd gear at high revs. I think someone said you can pop it into second, clutch in , and rev it quite high, and listen for it.
2005 Yamaha R6
The last post was made 19 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 60.33 Kb
