| Dan 4RR |
 Dan 4RR World Chat Champion
| veeeffarr |
 veeeffarr Super Spammer
| Blau Zedong |
 Blau Zedong Banned
| veeeffarr |
| Trip |
 Trip Brolly Dolly
| veeeffarr |
| Dan 4RR |
 Posted: 22:17 - 14 Mar 2007 Post subject: |
You can make gaskets from gasket paper which is cheap and sold everywhere (and for some odd reason smells like piss). I've made dozens of gaskets to get me out of trouble over the years. First place the gasket paper over the cover/casing and use a tiny hammer to tap around the end of the dowels that most cases have to cut the proper-sized hole in the paper. The paper will then be sitting on the dowel. now press the paper all the way to the sealing face and then draw around with a pencil. Either tap-out the holes with a small ball-pein hammer or use a bolt poked down them and tapped gently to mark position then use a leather-punch/gasket punch to make the holes. Alternatively use a battery-drill and appropriately-sized bit to drill them out through thecasing holes while resting on a wooden surface. Cut the inside profil out with a scalpel and the outside with scissors. ____________________ a.k.a 'Geri'
 Posted: 22:23 - 14 Mar 2007 Post subject: |
DON't use silicone or any other liquid-gasket material if you can help it. If you must, use only the most thin smear you can get away with. Remember if it squeezes-out on the outside it will have squeezed-out on the inside and that means you potentially have liquid gasket floating around in the sump to clog-up your oil strainer. Seen many an engine ruined by that stuff.
If you must use a sealer, or if you want to seal ahead-gasket or horizontally-split cases, I would reccoment this:
https://www.jlindustrial.co.uk/CGI/INSRCH?ns=1&oldNtt=&oldNtk=&oldURLVar=&scrNtt=PMX-80697H&Ntk=Keyword+Search&x=34&y=13 ____________________ a.k.a 'Geri'
| WavyGravy |
 WavyGravy Scooby Slapper
| Resurrection |
 Resurrection Ballast Boy
| bish777 |
 bish777 World Chat Champion
| Walloper |
 Walloper Super Spammer
 Posted: 03:26 - 15 Mar 2007 Post subject: |
There is a whole industry out there working on Gasket/Seal/Sealant solutions.
But you don't need any of that tosh.
A Crisp Bag, Cadbury Dairy Milk Wrapper or lick'n' stick The Back Page of the Daily Star on and it should be OK.
 ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Walloper |
 Posted: 04:14 - 15 Mar 2007 Post subject: |
Stole:
A gasket is a mechanical seal that fills the space between two objects, generally to prevent leakage between the two objects while under compression. Gaskets save money by allowing less precise mating surfaces on machine parts which can use a gasket to fill irregularities. Gaskets are commonly produced by cutting from sheet materials, such as gasket paper, rubber, silicone, metal, felt, fiberglass, or a plastic polymer. Gaskets for specific applications may contain asbestos. It is usually desirable that the gasket be made from a material that is to some degree compressible such that it tightly fills the space it is designed for, including any slight irregularities.
One of the more desirable properties of an effective gasket in industrial applications for compressed fiber gasket material is the ability to withstand high compressive loads. Most industrial gasket applications involve bolts exerting compression well into the 14 MPa (2000 psi) range or higher. Generally speaking, there are several truisms that allow for best gasket performance. One of the more tried and tested is: "The more compressive load exerted on the gasket, the longer it will last". There are several ways to measure a gasket material's ability to withstand compressive loading. The "hot compression test" is probably the most accepted of these. Most manufacturers of gasket materials will provide or publish these results. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Dan 4RR |
 Posted: 12:41 - 15 Mar 2007 Post subject: |
Thanks for the replies. Should have mentioned this earlier, but the reason I asked is because my dad works down the pit and they use massive gear boxes (normally the size of 1-2 minis) to pull mile long conveyor belts and they take some serious hammer and need to be serviced quite regularly and according to my dad they use the silicone to seal the cases together and I just wondered if this was possible with bikes
Upon closer inspection today, I noted that certain parts of my CBR crankcase does have this rubber type of material instead of a normall paper casket  ____________________ Humans....the largest form of cancer the world has ever seen!
Speed Cameras - Putting goverment revenue before public safety! |
| bish777 |
The last post was made 19 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
