ER-5 starting trouble
chris___
PostPosted: 17:25 - 17 Mar 2007    Post subject: ER-5 starting trouble Reply with quote
Hi all,
My mrs brought an ER-5 the other day for when she passes her test.
It started in the guys garage (he hadn't warmed it up, I checked)
But when I got it home it wouldnt start very well at all, took ages to fire up so I changed the plugs and filled the tank up, just to make sure, but still no look.
It'll start after a while and be fine for about a minute after turning it off but after that it'll take ages to start. Confused
Gonna do an oil change in a few days but dont know how much difference that'll make.
Cheers for any help Thumbs Up
Yamaha rxs100 > Kawasaki ZZR600 > Kawasaki ZX6R > Honda Hornet 600 > Honda Bros 400 > Suzuki SV650S K2
Bikepics page
Ratbag
PostPosted: 17:49 - 17 Mar 2007    Post subject: Reply with quote
Essentially two things are the cause of poor starting and running one is a lack of sparks the other a lack of fuel.
If you have decent sparks happening at the right time then you should look at the carbs the most likely cause will be a blocked jet so a strip and clean will be in order.
Ratbag
Tim..
PostPosted: 17:54 - 17 Mar 2007    Post subject: Reply with quote
Fuel filter might be blocked?
if it has one
www.marshallracing.co.uk
chris___
PostPosted: 19:03 - 17 Mar 2007    Post subject: Reply with quote
Cheers guys Thumbs Up
Will give these a check over tomorrow
Bikepics page
chris___
PostPosted: 14:28 - 18 Mar 2007    Post subject: Reply with quote
Can someone just inform me of the best way to clean carbs please?
The only experience Ive had with them is when Ive restricted my old ZZR600, which just involved loosening the jubille clips to pull the carbs off, I didnt completely dissconnect the carbs when I did that.
Chris
Bikepics page
Whosthedaddy
PostPosted: 14:35 - 18 Mar 2007    Post subject: Reply with quote
When I was on an ER5 on my DAS they seemed to be a bitch to start anyways, very tricky when trying to start with any kind of throttle, more timing than anything.
stu_m
PostPosted: 15:59 - 18 Mar 2007    Post subject: Reply with quote
some bikes can be a bitch to start if your not used to them
i picked up two bikes from my mates in winchester the other week i couldnt start one of them he came across put a bit of choke on hit the starter and it went first go
what im saying is some bikes have to be started different to others some with choke some without some with a little throttle etc etc
hope that helps Confused
Stu
davidimurray
PostPosted: 22:28 - 18 Mar 2007    Post subject: Reply with quote
Generally with my ER5 I find the technique is full choke, no throttle and hold the starter. Should start pretty quick. Since I popped some Iridium plugs in mine it starts on the button.
Check the battery voltage - they seem to put a good load on the battery so a slightly low charge can make all the difference.
The last post was made 18 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 56.41 Kb
