| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 14:04 - 18 Mar 2007 Post subject: Oh well, you live and learn |
I wont have a bad word said against the little monkey and its Chinese origins, but I did have to do some work to it recently
Simple job really, the chain was rusty and needed lubing. Upon inspection I noted that it was a little slack. I guessed this anyways as you could hear the chain rattle when down gearing.
So, with a cloth in gloved hands, oil was poured on and then gently massaged into the chain with the rear wheel being turned to evenly distribute the lube.
So one down, onto to the next job, taking up the slack of the chain.
With the bike balanced on a tool box, got a 10mm spanner and started to tighten the chain adjuster nut, nothing, tried the other side, nothing Then attempted to try and loosen the nut, still nothing. The nut would just spin on the threaded chain adjuster?
I then realised that I hadn't undone the rear wheel spindle so the wheel wouldn't have gone anywhere anyways So I then had to spend the huge total of £7 inc p&p for new adjusters as I had worn away the threads
They seem a little shorter than the old ones but fit none the less. Not a huge amount of adjustment, either slack or tight, so tight it is .
Went for a test spin as it will be my only mode of transport next week whilst the car is in the garage for work.
Little bit wobbly in all of this wind and a little unstable on the corners.
Inspected the chain post test ride only to see that the rear wheel is absolutley covered in oil from cast off from the chain
Lesson learnt, be gentle, think things through and dont rush.
What mistakes have you done that can we all learn from  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Marcg868 |
 Marcg868 World Chat Champion
 Posted: 14:10 - 18 Mar 2007 Post subject: |
Bought a CBR 125  ____________________ JACK, MISS YOU LOADS YOU LEGEND. |
| ram_doom |
 ram_doom World Chat Champion
 Posted: 14:14 - 18 Mar 2007 Post subject: |
Broke a stud mount off engine on cbr600f jb welded back on and was fine ever after
Lesson learned: Dont use non crushable copper washers, and when it feels like its about to break, it probably is... ____________________ TL1000s, KDX200 |
| Whosthedaddy |
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 15:19 - 18 Mar 2007 Post subject: |
Rode a DT50 flat-out under a barrier once as a teen whilst flat on the tank thinking I was some kind of stuntman. Smacked my spine good and proper. I was sure if I tried it again I could do it so I did it on the way back and guess what? Yep, smacked my spine again
Never tried it since  ____________________ a.k.a 'Geri'
| SoND |
 SoND World Chat Champion
| TheShaggyDA |
 TheShaggyDA Repost Police
The last post was made 19 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
