Have you ever changed sprockets?
kawashima
PostPosted: 13:59 - 19 Mar 2007    Post subject: Have you ever changed sprockets? Reply with quote
Have you ever changed sprockets? and What did it result?
<Me>
Honda C50 : F14 to F15 : Topspeed increased from 38 to 39.
Honda CB400SF : R44 to R39 : Topspeed decreased from 119 to 115, petrol consumption got worse from 12.5m/L to 12.
(I expected topspeed and better consumption but both got worse.
My worst custom ever...)
W650 : R37 to R38 : Topspeed same 119, consumption same 15m/L
(But I got nice acceleration and pick-up)
Phil_C
PostPosted: 14:08 - 19 Mar 2007    Post subject: Reply with quote
Yes I did, but to same size. Sorry, no help whatsoever Smile
Finglonga
PostPosted: 14:17 - 19 Mar 2007    Post subject: Reply with quote
Only did it with my KMX125 but along side alot of engine changes so can't say the advantages it had on its own.
Andy Sez....
F.Y.Y.F.F.
snapperslappe...
PostPosted: 14:35 - 19 Mar 2007    Post subject: Reply with quote
i changed both front and rear for the same setup, and added a scottoiler, and now get a handfull more mpg? might have something to do with an altered riding style, smoother and more mechanically sympathetic,...
but woud'nt reducing the amount of teeth on the front result in higher wear? Faster rotation ect ect?
Phil_C
PostPosted: 14:46 - 19 Mar 2007    Post subject: Reply with quote
I gotta admit since I changed my front, rear and chain the pull is a lot smoother after a gearchange. I think the chain was too loose before, resulting in a "slap".
PostPosted: 14:56 - 19 Mar 2007    Post subject: Re: Have you ever changed sprockets? Reply with quote
Never really paid much attention to fuel economy, only ever gone down from the original gearing.
Tuned ZX9:
Original would probably top out 170-175.
Downgeared would top out 140-150 depending on what I had on it at the time.
Did about 90miles to a full tank.
Open the throttle hard in first and it'll smack you in the face.
CRM125
Original geared for 100mph, would do 80mph.
Went 1 down/10 up. Will now top out at around 60mph in top gear.
First gear still isn't great, but the closer gear ratios give you more room to play off road.
99 R6:
2 down/2 up. Similar top speed, but first and second much more lively now.
Reducing the teeth on the front does result in higher wear and a very marginal loss of power. However, increasing the teeth on the back is also going to mean a little more rotating mass.
kawashima
PostPosted: 15:10 - 19 Mar 2007    Post subject: Reply with quote
This was very helpful for me. I didn't think of it at all till now.
kenny
PostPosted: 18:26 - 19 Mar 2007    Post subject: Reply with quote
changed the sv front and rear sprockets last night funnily enough but kept same size but have changed em on other bikes, i suppose it depends on the bike power if you go for smaller ones on the front your going to get more top end but if your bike hasnt got the power to get it there then dont bother and visverser if you change for bigger ones on front u'll get more acceleration but you'll be changing gear more quicker which would also result in losing time so ideally you wont to be getting the most speed out of each gear before you knock up which might be better to go for a longer gear and add some extra ponies to the engine.
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
SoND
PostPosted: 19:43 - 19 Mar 2007    Post subject: Reply with quote
-1 On the front sprocket of the GS125.
Top speed increased a bit because the bike could rev out easier in 5th. Would usually struggle unless there was a tail wind.
kawashima
PostPosted: 22:23 - 19 Mar 2007    Post subject: Reply with quote
Looks like opposite (smaller one on the front : more acceleration, bigger one : more top end), but I agree it depends on the bike power.
Nice choice Thumbs Up Best case ! Both better acceleration and top end.
<summary>
+1 on Front : When you want to reduce 2 or 3 on Rear, nearly same change and sometimes don't need to change chain, low cost.
But this change often doesn't result in better economy or top end on both big and small bike, cause normal gear ratios are often considerd of economy.
-1 on Front: When you want to increace 2 or 3 on Rear, nearly same change and sometimes don't need to change chain, low cost, But it often result in higher wear and a very marginal loss of power.
But sometimes result in good on smaller bikes like 125.
+1or-1 on Rear: good for fine adjustment.
+2or +3 or +more on Rear: good for acceleration, no worry on higher wear and marginal loss of power, but a little more rotating mass, and sometimes shorter tank milage.
<small question>
I also found F15+R45 or F14+R42(R number of teeth is devided by F number) cases are not good on biased wear, but some bike adopt it as normal set, so I'm not sure.
kenny
PostPosted: 18:21 - 21 Mar 2007    Post subject: Reply with quote
yea your right smaller on front gives better acceleration bigger bigger top end , got me front and back mixed up lol Laughing
kenny
PostPosted: 18:23 - 21 Mar 2007    Post subject: Reply with quote
you'll probberly have to get a few different sets of gears to mess around with the settings till your happy
CoronaBoner
PostPosted: 20:02 - 21 Mar 2007    Post subject: Reply with quote
01 Mille
Stock was 17/42, I got 172mph, may have gone alittle more.
Now have 16/44 and taken it to around 165, and did notice a gain at the bottom (even more so now with a PC) but also noticed I can only get 90 miles to a full tank.
2004 RSV Factory
Cluck cluck chicken
kenny
PostPosted: 18:51 - 22 Mar 2007    Post subject: Reply with quote
yea the fuel tends to run out quicker if you change your gears so you have more accelration as your going to be at the redline in last gear more often did that to me on my nsr when i had standard cogs on so i put a set on for more top end speed
The last post was made 19 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 82.86 Kb
