| Feasty |
 Feasty World Chat Champion
 Posted: 14:42 - 21 Mar 2007 Post subject: Throttle cable sticking! |
Hey All
Quick question, my accelerator cable is a bit stiff and if I twist the throttle handle back it doesn't close back straight away... thinks about it for a bit, slowly closes, then finally goes back to idle position!
I've tried WD40 down the cable from the handle end, didn't make much difference. Have also tried oil in the same way but still doesn't do anything. I've tried following the cable but it disappears under the petrol tank, I 'think' it goes directly into the carb but am not sure and probably wrong . Is there anything else I can do?
Advice please!!
(P.S Bike is a 2yr old XR125) |
| virus |
 virus World Chat Champion
 Posted: 14:53 - 21 Mar 2007 Post subject: |
I have the same problem with my CG,
make sure the throttle grip spins smoothly with and without the case that holds it to the bars, and that the carb end runs smooth (try moving the accelerator linkage on the side and seeing if it snaps back) If not then order a new cable and whilst its on the way keep it oiled as much as possible. ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Feasty |
 Posted: 15:38 - 21 Mar 2007 Post subject: |
So I assume I should be able to see the throttle linkage on the carb? Only I've had a look but couldn't see anything moving when twisting the handle, it couldn't be buried inside the carb could it!?  |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 15:54 - 21 Mar 2007 Post subject: |
Try forcing the throttle closed, if that doesn't work then the problem is either a knackered cable or the throttle slide needs oiling. You can unscrew the top of the carb (about 1 and a half inches wide) where the throttle cable sticks out vertically. Then you should pull the slider out most of the way (about an inch and a half vertically) and lube it up with good old wd40.  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
| Marci |
 Marci Brolly Dolly
| Feasty |
| ZaphodBeeble |
There is a gap of 287 days between these two posts... |
| Feasty |
 Posted: 11:45 - 03 Jan 2008 Post subject: |
hey all!
Just bringing this old thread back from the dead that I started ages ago!
The accelerator on my bike has been fine after the last episode (see my first post) after oiling the cable regurlarly and checking it.
However it's now started sticking again, only this time oiling the cable and the carb slider makes little difference. The slider and spring are fine, no rust or breaks so I'm assuming I'll need to replace the cable next?
If so, is it easy to replace the carb end of the cable? The handle end I have no problem with, but I'm worried if I take the carb slider out things will go wrong... petrol will spill out, something will fall into the carb etc... any advice on doing this please?
Also it'd help if anyone could look at the diagram above and tell me what all the numbers point to!
Thanks!  ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). |
The last post was made 18 years, 228 days ago. Instead of replying here, would creating a new thread be more useful? |
