Crunch ?
Jadc
PostPosted: 09:23 - 22 Mar 2007    Post subject: Crunch ? Reply with quote
Yeh hello guys
Bike = honda xr125
When im going up the gears for e.g
1st gear i pull the clutch in and goe up a gear (2nd)and then pull the clutch out slowly and when i do that the gears crunch or grind if you want to call it but in goes into the gear ...but its embarassing sometimes hehe
it happens sometimes and sometimes its fine..
any idea's what im doing wrong or if anything to do with bike?
killa
Won't Shut Up
PostPosted: 09:27 - 22 Mar 2007    Post subject: Reply with quote
Your english is pretty bad... Confused pull out the clutch??
Sometimes changing from 1st to 2nd you can get a crunch but that’s usually down to your timing.
Just pulling in the clutch shouldn’t do this.
How is your clutch cable, is it still tight?
Jadc
PostPosted: 09:35 - 22 Mar 2007    Post subject: Reply with quote
sorry about the bad english lol
hopefully you understand what i mean...
sometimes when it happens i do fiddle with the clutch (pull the flap back and un-screw it and tighten it so theres a little play in the clutch area.
and timing could be it aswell..
ram_doom
PostPosted: 09:36 - 22 Mar 2007    Post subject: Reply with quote
Adjust chain, make sure clutch is fully disengaged when you pull the lever, and finally, make sure you give it a good solid kick up the gearbox when shifting Wink
TL1000s, KDX200
Jadc
PostPosted: 09:38 - 22 Mar 2007    Post subject: Reply with quote
well when i pull the clutch i notice sometimes when i let it goe its abit sluggish meaning sticky lol...hard to explain and i will look at the chain also thanks Razz
all new to this shinizzle ill get there
Feasty
PostPosted: 10:25 - 22 Mar 2007    Post subject: Reply with quote
Hi there
I have an XR125 and it does the same thing. It's like the gears grate whenever you change gear... However I have been reliably informed this is due to the clutch being a very basic setup and doesn't have an extra part within the clutch to make the biting point smoother that other more expensive bikes would have. (I can't remember what the parts are called).
You can minimise this with careful clutch control, and you get more used to it as time goes by. I can ride now with hardly any grating going on - you just have to balance the clutch with the revs rather than just letting the clutch out then accelerating.
Hope this helps!
Jadc
PostPosted: 11:46 - 22 Mar 2007    Post subject: Reply with quote
has done thank you jus glad it isnt my bike going down the drain lol.
Jull
PostPosted: 14:11 - 22 Mar 2007    Post subject: Reply with quote
Yep as Beanfeast says Thumbs Up
My XR125 was very clunky - but you definitely know when you've got it in gear!
You should hear my hubby's Fazer - you could hear him put it in first from the end of the street Shocked
Feasty
PostPosted: 14:32 - 22 Mar 2007    Post subject: Reply with quote
The most difficult thing I find to do with this bike is set off quickly! Once in 2nd gear I'm away, it's just the initial standing start where I always find 1st gear a nightmare until the clutch is fully out and the rev's are up high! Embarassed
Finglonga
PostPosted: 21:37 - 22 Mar 2007    Post subject: Reply with quote
If you put the bike into first then roll the bike back and forth before you start it then the clunk will be reduced. Its only oil drag on the clutch plates.
As for the 1st to 2nd change, it wont happen if you get the engine speed right to the gearbox speed. basically its user abuse and will come with practise and nothing to do with the design of the clutch.
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 64.07 Kb
