Need a tiny oil pump.
PostPosted: 16:15 - 29 Mar 2007    Post subject: Need a tiny oil pump. Reply with quote
Ok folks this will get you thiking.
I need an oil-pump out of a small 4-stroke. Something like a 50cc or 125 possibly.
It must be physically as small (thin mainly) as possible. It must have a fully-separate housing from the engine casing, in other words if it's removed from the bike it must still work as a pump, but I don't mind making a backplate for it. It should ideally also normally run at crank speed or higher.
Any ideas?
Odie
PostPosted: 16:19 - 29 Mar 2007    Post subject: Reply with quote
try a fuel injector unit, turn on the power and away it goes.
Seen them used as chain lube system
PostPosted: 16:24 - 29 Mar 2007    Post subject: Reply with quote
Hmm good lateral thinking, but this must be an engine-oil pump.
PostPosted: 16:40 - 29 Mar 2007    Post subject: Reply with quote
What you lubing?
Would a 2-smoke autolube pump not do it? or would it not have a high enough throughput? Early suzuki ones run at the same rev speed as the rev counter cable.
I've seen a scotoiler used to lube the bearings in the supercharger on a top-fuel drag bike.
These are very good if you can work out how to fit it in your application:
https://www.morgo.co.uk/rotary.html
Jamie S
PostPosted: 17:28 - 29 Mar 2007    Post subject: Reply with quote
what ya betting , hes trying to make a home made scott oiler Razz
PostPosted: 20:31 - 29 Mar 2007    Post subject: Reply with quote
How about a seperate oil pump from an older British bike. Such as a Vincent one? Think there are modern replacements available.
PostPosted: 05:01 - 30 Mar 2007    Post subject: Reply with quote
I like the look of that Morgo unit, seems perfect but there's no indication on price or dimensions at first glance. It also quotes scavenge in the text which is what I want it for - to scavenge oil from my turbo.
Keith my mate has a couple of old triumph pumps but I didn't want something that I migh have trouble replacing/servicing.
There is a very nice bespoke pump I could egt from the states that is 100% specific to my bike model ad the application for around a couple of hundred quid plus shipping. I just had the idea I might be able to manufacture something, since I've made everything else so far.
bish777
PostPosted: 19:13 - 30 Mar 2007    Post subject: Reply with quote
https://www.accusump.com/acc_products/acc_units.html
this any good?
GSXR1100J
The last post was made 18 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 58.21 Kb
