| Pete. |
 Pete. Super Spammer
 Posted: 16:15 - 29 Mar 2007 Post subject: Need a tiny oil pump. |
Ok folks this will get you thiking.
I need an oil-pump out of a small 4-stroke. Something like a 50cc or 125 possibly.
It must be physically as small (thin mainly) as possible. It must have a fully-separate housing from the engine casing, in other words if it's removed from the bike it must still work as a pump, but I don't mind making a backplate for it. It should ideally also normally run at crank speed or higher.
Any ideas? ____________________ a.k.a 'Geri'
| Odie |
 Odie World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 16:24 - 29 Mar 2007 Post subject: |
Hmm good lateral thinking, but this must be an engine-oil pump. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 16:40 - 29 Mar 2007 Post subject: |
What you lubing?
Would a 2-smoke autolube pump not do it? or would it not have a high enough throughput? Early suzuki ones run at the same rev speed as the rev counter cable.
I've seen a scotoiler used to lube the bearings in the supercharger on a top-fuel drag bike.
These are very good if you can work out how to fit it in your application:
https://www.morgo.co.uk/rotary.html ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Jamie S |
 Jamie S World Chat Champion
 Posted: 17:28 - 29 Mar 2007 Post subject: |
what ya betting , hes trying to make a home made scott oiler  |
| Kickstart |
 Kickstart The Oracle
| Pete. |
 Pete. Super Spammer
 Posted: 05:01 - 30 Mar 2007 Post subject: |
I like the look of that Morgo unit, seems perfect but there's no indication on price or dimensions at first glance. It also quotes scavenge in the text which is what I want it for - to scavenge oil from my turbo.
Keith my mate has a couple of old triumph pumps but I didn't want something that I migh have trouble replacing/servicing.
There is a very nice bespoke pump I could egt from the states that is 100% specific to my bike model ad the application for around a couple of hundred quid plus shipping. I just had the idea I might be able to manufacture something, since I've made everything else so far. ____________________ a.k.a 'Geri'
| bish777 |
 bish777 World Chat Champion
 Posted: 19:13 - 30 Mar 2007 Post subject: |
The last post was made 18 years, 268 days ago. Instead of replying here, would creating a new thread be more useful? |
