Crack in airbox at carb inlets
MarkJ
PostPosted: 17:44 - 29 Mar 2007    Post subject: Crack in airbox at carb inlets Reply with quote
Hi all. I've got a crack on my left carb inlet on the outside. It seems to me the standard Hornet airbox is a few seperate parts plastic welded together, and the funnels which fit on the ends of the carbs seem to be done this way. This plastic weld seems to have come loose/cracked on the left side into carb #1, however I've had no performance issues or anything.
I was just wondering what I could use to seal this crack up. I'd ideally like something that is black in colour as this crack can just be seen from the outside.
mchaggis in this thread reccomends epoxy resin. Do places like B&Q sell this stuff? I'm a newb when it comes to sealants.
Pics attached of the crack.
moto_psycho
PostPosted: 18:38 - 29 Mar 2007    Post subject: Reply with quote
silicone sealant? just give it a while to dry, or just ditch it n slap on some k&n's Thumbs Up Twisted Evil Middle Finger
meant to be restricted... aint Twisted Evil
timjim
PostPosted: 18:56 - 29 Mar 2007    Post subject: cracked airbox Reply with quote
How about Araldite Rapid?
moto_psycho
PostPosted: 19:18 - 29 Mar 2007    Post subject: Reply with quote
BLUEX5 wrote:
It'll run like a sack of shite on K&N's, so best not.
Silicon sealant, or get another airbox.
its called a rejet! thats the fun of bikes!
Finglonga
PostPosted: 20:16 - 29 Mar 2007    Post subject: Reply with quote
Its called a ball ache, just go with the silicone sealant. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
PostPosted: 20:42 - 29 Mar 2007    Post subject: Reply with quote
Epoxy resin should do the job fine. Araldite is common and readily available. It sets clear but I'd recommend building up a 'bead' of the stuff over the crack so it's well covered.
Araldite 'rapide' sets in about 4-8 hours. Araldite 'precision' takes 24 hours but is stronger. You can buy it in any hardware store/ironmongers and probably most supermarkets and general stores too.
Two tubes, one has the resin, one has the hardner. They stay liquid until mixed then slowly set. You squirt equal quantities of each onto a bit of shiny cardboard and mix them together then apply it over the crack and leave to harden. Don't let the ends of the tubes touch one another or mix up the caps or they'll stick on.
You could also 'weld' it with a hot soldering iron. Melt a series of diagonal 'stitches' across the crack then melt it smooth along the crack. It's not load-bearing so this should work ok.
The last post was made 18 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 54.59 Kb
