Pipe dripping petrol - I think
gypsyjackson
PostPosted: 13:48 - 29 Mar 2007    Post subject: Pipe dripping petrol - I think Reply with quote
Hi - this will be a very easy one, I'm sure, but I'm still new to all this so I would be grateful for some advice.
Just come back from a ride to find one of the hoses from my carb is dripping petrol (at least it smells and looks like petrol, but I don't want to jump to conclusions).
I've attached two pics, the arrow is pointing to the pipe in question,which is the black one coming from the bottom of the carb. I've had a look in the Haynes, and it appears this is a 'Drain pipe'. I assume the orangey one is the breather pipe.
I have had a look around on here and found the following thread, which seems like it might be useful:
https://www.bikechatforums.com/viewtopic.php?t=68131&highlight=fuel+drain+pipe
However, I just wanted to check that I'm reading the situation correctly.
Thanks.
Finglonga
PostPosted: 19:13 - 29 Mar 2007    Post subject: Reply with quote
Make sure that screw is tight(on the bottom of the float bowl) as fuel needs to pass that to get into the pipe.
Andy Sez....
F.Y.Y.F.F.
mchaggis
PostPosted: 12:30 - 30 Mar 2007    Post subject: Reply with quote
Could be a float needle stuck so your carbs are overflowing. Tap it with a rubber hammer or the handle of a screwdriver/ similar.
I must not be a troll...
Mmmm, Guinness
Finglonga
PostPosted: 12:34 - 30 Mar 2007    Post subject: Reply with quote
The black tube isn't an overflow though its the float bowl drain tube. Wink
Andy Sez....
F.Y.Y.F.F.
gypsyjackson
PostPosted: 09:44 - 01 Apr 2007    Post subject: Reply with quote
Did this - it was about 1/8 of a turn loose, and the drip has stopped. Cheers!
Finglonga
PostPosted: 13:34 - 01 Apr 2007    Post subject: Reply with quote
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 48.82 Kb
