YBR clutch problems
lewbear
PostPosted: 12:12 - 30 Mar 2007    Post subject: YBR clutch problems Reply with quote
The clutch on my YBR has become looser lately, and doesn't seem to spring back into place, so when I pull it in, although it returns most of the way, I have to push it the last few centimetres to the rubbing housing. Is this normal? If not, how do I fix it? Cheers.
hmmmnz
PostPosted: 12:23 - 30 Mar 2007    Post subject: Reply with quote
lol, the cable id probly full of gunk
take the cable out of the lever and loosen it down by the engine, cut a plastic bag and tape it at the top and fill with oil so it can seep into the cable, move the cable up and down so the oil goes into the cable, keep doing that untill oil drips out of the bottom and the cable is easy to move
ill post a pi in a second
the humans are dead
I kick arse for the lord
hmmmnz
PostPosted: 12:33 - 30 Mar 2007    Post subject: Reply with quote
https://i58.photobucket.com/albums/g257/hmmmnz/oil.jpg
sorry about the crap pic, but i think you'll get the idea
the humans are dead
lewbear
PostPosted: 13:04 - 30 Mar 2007    Post subject: Reply with quote
Hmm, I see. What oil should I use? Any particulars?
hmmmnz
PostPosted: 13:09 - 30 Mar 2007    Post subject: Reply with quote
some old oil that you have lying about, nothing special, i sapose the thinner the better, but in the past i have just used the old oil from an oil change, or done the same thing with wd 40, except with out the plastic bag, and just sprayed it at the top and moved the cable about.
up to you Mr. Green Thumbs Up
have fun Mr. Green
the humans are dead
Matt06
PostPosted: 13:45 - 30 Mar 2007    Post subject: Reply with quote
WD40! Shocked
Current: MT-10, Bandit, Grom, GPZ500
Previous: YBR125, GSXR400, ZXR400, MT-03, NTV650, R6, z750, ZX6R, MT-09
hmmmnz
PostPosted: 15:14 - 30 Mar 2007    Post subject: Reply with quote
Matt06 wrote:
WD40! Shocked
yes thats right "WD40"
why does everyone always get there hackles up about wd40
have a read of https://www.bikechatforums.com/viewtopic.php?t=98167&highlight=wd40
its only the cable nothing serious
the humans are dead
Andyco11
PostPosted: 16:41 - 30 Mar 2007    Post subject: Reply with quote
hmmmnz wrote:
Matt06 wrote:
WD40! Shocked
Yes it only a cable but WD40 also removes wax based lubricants and some grease based ones as well.
so if you use it it dose free the item up temporary but then it will seize even worse when the WD40 has evaporated
would never use the stuff its horrid
XS250 Special - XS250 US Custom - XS250 Special Jap Import with YICS Engine
The Florida Forum
hmmmnz
PostPosted: 21:43 - 30 Mar 2007    Post subject: Reply with quote
i used it on my gs over 6 months ago on the throttle cable, and there is no worries there, it still moves freely.
wd40 isn't the devil Very Happy
i did recomend oil first off.
but each to their own
the humans are dead
Spoon261
PostPosted: 11:35 - 31 Mar 2007    Post subject: Reply with quote
Their is another option, replace the cable, a universal clutch cable only costs £2.99 at least that’s what the Hein Gericke shops book says, I bet loads of other shops are around the same price.
My Honda CG125 is about to hit 2 years old and has done 10,000 miles and I have never had to even oil it, theirs no sign of oil needed, I even asked a mechanic to operate the clutch and he confirms its still ok.
Makes me wonder if the YBR125 is using a low quality cable, replacing it with a universal cable could make using the clutch easier and less maintenance in the future?
The last post was made 18 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 66.86 Kb
