2 Stroke Unreliability.
Itchy
PostPosted: 20:17 - 08 Apr 2007    Post subject: 2 Stroke Unreliability. Reply with quote
Why are they so unreliable ? , ie GSX Mick at squires looked worried his NSR250 might seize at any moment, erm why is this? .
4 strokes generally only seize with no oil or if they over heat, last few months I must have seen
5-6 'blown up' RGV250s tempting but I was put off by the perceived unreliability issues,
surely if you give them plenty of 2 stroke oil , and don't over heat them they'll be fairly reliable
right RIGHT? .
Any thoughts?
Thanks.
st3v3
PostPosted: 20:43 - 08 Apr 2007    Post subject: Reply with quote
I would of thought, as is mine, as long as there is a nice amount of oil, petrol and water(not to mention general usual maintenance) any 2t would be Ok. Thumbs Up
Finglonga
PostPosted: 20:46 - 08 Apr 2007    Post subject: Reply with quote
They are mega reliable until they are tuned by people who don't know what they are doing or don't know that once they are tuned they need a stripdown every X number of miles.
Many Many moons ago I had a trusty GP100 (with a tuned 125 lump in it) never let me down as it was looked after. Sold it to a friend who I warned it needed stripdowns to keep it sweet . . . . 2Weeks later it was seized up . . . then again, then again. He sold it in the end as it was unreliable. Rolling Eyes
Andy Sez....
F.Y.Y.F.F.
PostPosted: 20:50 - 08 Apr 2007    Post subject: Re: 2 Stroke Unreliability. Reply with quote
right RIGHT? .
Any thoughts?
Thanks.
They aren't reliable for use daily. They are reliable as occasional blast and occasional track use bikes, but I'm currently rebuilding my RGV which blew up on its third trackday.
Two strokes have a total loss lubrication system where the oil is mixed with the fuel and the crankshaft acts as a kind of pump which pre pressurises the mixture. Because the crank etc doesn't run in a bath of oil, it means that it cannot run plain bearings. Needle roller and ball bearings are less reliable, although they can work without or with less lubrication than plain bearings.
If the same amount of research and development that has been put into four strokes was put into two strokes, they would be more reliable, probably cleaner and certainly more powerful than the equivalent four stroke. And less complicated.
But the bottom line is, yes they aren't on the whole as reliable as four strokes.
brooky
PostPosted: 20:51 - 08 Apr 2007    Post subject: Reply with quote
Bikes like yer NSR, RGV's and TZR's were already in a high state of tune when they left the factory, And as such they wont be as reliable due to the performance they deliver.
When it comes to things like this you cant have it all. You either have the performance and lose some reliability, or you have the reliability and loose the performance.
Just the way two strokes are, I Love 'em! Very Happy
Suzuki GSX-R 750 K6.
mattgirv
PostPosted: 21:27 - 08 Apr 2007    Post subject: Reply with quote
I wouldn't go so far as to say a 2 stroke engine is unreliable.
Compared to 4 stroke engines they need more maintenance. A lot of bike owners I know aren't exactly vigorous with maintenance anyway, let alone with a bike that demands more attention.
Yeah tuning would affect life of the engine, but usually it is because one thing has been changed, which causes something else strain because it cannot cope with the change. Especially people on a budget. One person I knew bought a race can for his NSR. Lovely, but he didn't rejet his carbs or do any sort of adjustment to cope with the change. His bike ran like shit for it. I'm sure it didn't help with the overall life expectancy of the engine.
JakeyR
PostPosted: 21:46 - 08 Apr 2007    Post subject: Reply with quote
In 6 months i've gone through 3 head gaskets (yes, 3!) and the engine has seized once due to the oil pump failing, and its an 05 model, wouldn't expect this many problems but it's all sorted now Neutral
PostPosted: 21:47 - 08 Apr 2007    Post subject: Reply with quote
I must say that anything that has caused one of my 2-smokes to let go would have done the same on a 4-stroke.
Err. Had a crack in an inlet manifold, ran lean and holed a piston. Points shifted, ignition retarded and holed a piston and I had a CDI pack in.
There again, I had the conrod fail on what is supposed to be an ultra reliable 4-stroke single. Big ends collapsed on my mates GPZ305.
An important consideration is that when a 2-stroke lets go, you open it up to see how you're going to fix it. When a 4-stroke does so, you open it up out of morbid curiosity to see how many bits the inside of the engine is in before fitting a new one.
Al
PostPosted: 22:01 - 08 Apr 2007    Post subject: Reply with quote
I do about 6k a year on my vespa commuting and its fine, Ok it probably does preduce less power then a 4 stroke 125 but still...
I keep the oil topped up, change the plug every few months and a little bit of self servicing Smile . kept it going up fine so far.
In fact the motor is about the best bit, the rest of the vespa is starting to fall apart Sad
Yamaha FZR400RR 3tj
My Instagram Thingy
cagiva gezzer
PostPosted: 22:09 - 08 Apr 2007    Post subject: Reply with quote
My two stroke is running at 280BHP/L.
You have to expect any engine making that much power to let go with very little warning.
Each time it's had a fit it's given me warning, but only now am i able to realise it's on the way out.
Get a 2T that's making 4T power/L outputs and they're the most reliable and much loved engines in the world. i.e CRM250.
iooi
PostPosted: 22:11 - 08 Apr 2007    Post subject: Reply with quote
Never ever had any issue with my old 2 strokes, be that a AP 50, TS100, 2 x X7'S, LC350 or a DT125.
All the 250's & 350 did at least 10,000 miles a year on nothing more than std service and i never had to have a head off on any of them apart form the AP 50 when i stripped the thread on the spark plug Embarassed Was learning at the time. Embarassed
Fair to say that all apart from AP 50 were new, but apart from free 1st service never saw the dealer again.
phil_DT
PostPosted: 22:25 - 08 Apr 2007    Post subject: Reply with quote
Same here my Oil pump went on The '92 Dt50. Top end rebuild later and its running fine. I wuldn't trust it on a journey over 100 miles though. 2-stroke is a right buzz but there not the most reliable.
1992 DT80MX with Gianelli zorst and Mallosi Carb. Goes through engines faster than tyres.....
PostPosted: 22:31 - 08 Apr 2007    Post subject: Reply with quote
The solution to the problem is fuel injection.
Yamaha make, V5 2-stroke outboard motors which put out 250bhp. Reliable as you like.
EDIT: Also my classic project bike is a Suzuki T500. Injects the oil directly along the crank, which is sleeved for this purpose. They were very popular with amateur race teams in their day because you could do a whole season without having to strip the engine. Just change gearbox oil and plugs.
firefox
PostPosted: 22:42 - 08 Apr 2007    Post subject: Reply with quote
ive done 7000 miles on my dt stroke in 4 months and its still going strong
bye bye gti <^>( ' . ' )<^>
*officer* what caused the crash ? *firefox* you see that wall up there sir ?
*officer* yes what about it *firefox* i tooted my horn but it refused to move i had to teach it a lesson.
Ariel Badger
PostPosted: 22:46 - 08 Apr 2007    Post subject: Reply with quote
You are banging out 280 ponies, what bike is that?
cagiva gezzer
PostPosted: 22:56 - 08 Apr 2007    Post subject: Reply with quote
125cc running 35BHP - 35 x 8 =280.
The highly strung 125's / 250's will always have short lives.
st3v3
PostPosted: 22:58 - 08 Apr 2007    Post subject: Reply with quote
sorry, but I got my NS in october and used it everyday covering at least 10 miles, not a problem yet.*touches wood*
I would of said that, but going from york to sleights(nr whitby) on to scarborough then back to york in more-or-less an afternoon proved me wrong, simply topped up the oil when I got back, even averaged speeds around 70 for 2/3rds of the way from scarborough to york(enough to tag along with the big bikes for a bit) Thumbs Up
Ariel Badger
PostPosted: 23:03 - 08 Apr 2007    Post subject: Reply with quote
So they are just imaginary made up BHPs then not proper horses at all.
Jack_Cheese
PostPosted: 23:05 - 08 Apr 2007    Post subject: Reply with quote
They are reliable as long as you keep with the service schedule. They generally don't tolerate abuse as well as 4-strokes do, though.
Not warming them up is a sure fire way to kill them too, but when they do blow up, it costs feck all to rectify compared to a 4-stroke. If a 2-stroke seizes, you need a barrel re-plate, new piston, rings and gaskets. If a 4-stroke does it, you may need valves and timing mechanisms, too. then there's the added labour of timing it all up again.
As for not doing a 100 mile trip, i did a 280 mile round trip up round delivs bridge and god knows where and my Cagiva YES, CAGIVA didn't miss a beat the whole way.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
Ariel Badger
PostPosted: 23:18 - 08 Apr 2007    Post subject: Reply with quote
I rode a 250 RD LC all over Zimbabwe in the 80s, thrashed it on the blacktop and took het into the dirt a lot. I did thousands of miles and only problem I had was a worn gear selector fork.
Pte1643
PostPosted: 23:36 - 08 Apr 2007    Post subject: Reply with quote
Owned an RGV for 2 yrs, way back when.
Done 30 miles a day, work and back, (Yes, I used it as a commuter Confused ), everyday in all weathers (didn't have a car then).
She NEVER once missed a beat. Thumbs Up
JakeyR
PostPosted: 23:37 - 08 Apr 2007    Post subject: Reply with quote
you regret selling it?
bish777
PostPosted: 01:04 - 09 Apr 2007    Post subject: Reply with quote
My MZ was perfectly reliable.
Its just demented wasps like RS125s when ragged by wannabe racers that explode every five minutes.
GSXR1100J
MementoMori
PostPosted: 02:07 - 09 Apr 2007    Post subject: Reply with quote
I had a little RS50 for a year and a bit, and used to rag it around town and also to get me to college and back and not once did I have a problem with it, only menial electrical faults. It was a perfect little bike.
Then again, I am a girl so probably rode it like a fairy.
The tiger who came for a pint
Diggs
PostPosted: 08:53 - 09 Apr 2007    Post subject: Reply with quote
I rode my AP50 from Wakefield to Ipswich one dark, cold, long lonely night as a teenager and it didn't miss a beat. Only problem was I had to wait till 8 in the morning for petrol halfway down. 6 hours in the dark by the side of a road in the Fens is no fun...
Two strokes can be reliable if you remember to top up the oil and you clean the plugs every 500 miles of so, plus decoke and get handy with the circlip pliers.... They just need more maintenance, thats all!
I stripped the plug threads on my AP50 too... the 'bang!' it made when I tried to pull onto a roundabout and the plug hit the underside of the frame was quite impressive! Well, it impressed me... lol
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
The last post was made 19 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 134.99 Kb
