| Itchy |
 Itchy Super Spammer
 Posted: 20:17 - 08 Apr 2007 Post subject: 2 Stroke Unreliability. |
Why are they so unreliable ? , ie GSX Mick at squires looked worried his NSR250 might seize at any moment, erm why is this? .
4 strokes generally only seize with no oil or if they over heat, last few months I must have seen
5-6 'blown up' RGV250s tempting but I was put off by the perceived unreliability issues,
surely if you give them plenty of 2 stroke oil , and don't over heat them they'll be fairly reliable
right RIGHT? .
Any thoughts?
Thanks. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| st3v3 |
 st3v3 Super Spammer
 Posted: 20:43 - 08 Apr 2007 Post subject: |
I would of thought, as is mine, as long as there is a nice amount of oil, petrol and water(not to mention general usual maintenance) any 2t would be Ok.  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
| Finglonga |
 Finglonga World Chat Champion
 Posted: 20:46 - 08 Apr 2007 Post subject: |
They are mega reliable until they are tuned by people who don't know what they are doing or don't know that once they are tuned they need a stripdown every X number of miles.
Many Many moons ago I had a trusty GP100 (with a tuned 125 lump in it) never let me down as it was looked after. Sold it to a friend who I warned it needed stripdowns to keep it sweet . . . . 2Weeks later it was seized up . . . then again, then again. He sold it in the end as it was unreliable.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| MarJay |
 MarJay But it's British!
 Posted: 20:50 - 08 Apr 2007 Post subject: Re: 2 Stroke Unreliability. |
| Itchy wrote: | Why are they so unreliable ? , ie GSX Mick at squires looked worried his NSR250 might seize at any moment, erm why is this? .
right RIGHT? .
Any thoughts?
Thanks. |
They aren't reliable for use daily. They are reliable as occasional blast and occasional track use bikes, but I'm currently rebuilding my RGV which blew up on its third trackday.
Two strokes have a total loss lubrication system where the oil is mixed with the fuel and the crankshaft acts as a kind of pump which pre pressurises the mixture. Because the crank etc doesn't run in a bath of oil, it means that it cannot run plain bearings. Needle roller and ball bearings are less reliable, although they can work without or with less lubrication than plain bearings.
If the same amount of research and development that has been put into four strokes was put into two strokes, they would be more reliable, probably cleaner and certainly more powerful than the equivalent four stroke. And less complicated.
But the bottom line is, yes they aren't on the whole as reliable as four strokes. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| brooky |
 brooky Brolly Dolly
 Posted: 20:51 - 08 Apr 2007 Post subject: |
Bikes like yer NSR, RGV's and TZR's were already in a high state of tune when they left the factory, And as such they wont be as reliable due to the performance they deliver.
When it comes to things like this you cant have it all. You either have the performance and lose some reliability, or you have the reliability and loose the performance.
Just the way two strokes are, I Love 'em!  ____________________ Suzuki GSX-R 750 K6. |
| mattgirv |
 mattgirv Trackday Trickster
| JakeyR |
 JakeyR World Chat Champion
 Posted: 21:46 - 08 Apr 2007 Post subject: |
In 6 months i've gone through 3 head gaskets (yes, 3!) and the engine has seized once due to the oil pump failing, and its an 05 model, wouldn't expect this many problems but it's all sorted now  |
| stinkwheel |
 Posted: 21:47 - 08 Apr 2007 Post subject: |
I must say that anything that has caused one of my 2-smokes to let go would have done the same on a 4-stroke.
Err. Had a crack in an inlet manifold, ran lean and holed a piston. Points shifted, ignition retarded and holed a piston and I had a CDI pack in.
There again, I had the conrod fail on what is supposed to be an ultra reliable 4-stroke single. Big ends collapsed on my mates GPZ305.
An important consideration is that when a 2-stroke lets go, you open it up to see how you're going to fix it. When a 4-stroke does so, you open it up out of morbid curiosity to see how many bits the inside of the engine is in before fitting a new one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Al |
 Al World Chat Champion
 Posted: 22:01 - 08 Apr 2007 Post subject: |
I do about 6k a year on my vespa commuting and its fine, Ok it probably does preduce less power then a 4 stroke 125 but still...
I keep the oil topped up, change the plug every few months and a little bit of self servicing . kept it going up fine so far.
In fact the motor is about the best bit, the rest of the vespa is starting to fall apart  ____________________ Yamaha FZR400RR 3tj
My Instagram Thingy |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 22:11 - 08 Apr 2007 Post subject: |
Never ever had any issue with my old 2 strokes, be that a AP 50, TS100, 2 x X7'S, LC350 or a DT125.
All the 250's & 350 did at least 10,000 miles a year on nothing more than std service and i never had to have a head off on any of them apart form the AP 50 when i stripped the thread on the spark plug Was learning at the time.
Fair to say that all apart from AP 50 were new, but apart from free 1st service never saw the dealer again. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| phil_DT |
 phil_DT Nova Slayer
| stinkwheel |
 Posted: 22:31 - 08 Apr 2007 Post subject: |
The solution to the problem is fuel injection.
Yamaha make, V5 2-stroke outboard motors which put out 250bhp. Reliable as you like.
EDIT: Also my classic project bike is a Suzuki T500. Injects the oil directly along the crank, which is sleeved for this purpose. They were very popular with amateur race teams in their day because you could do a whole season without having to strip the engine. Just change gearbox oil and plugs. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| firefox |
 firefox World Chat Champion
| Ariel Badger |
 Ariel Badger Super Spammer
| cagiva gezzer |
| st3v3 |
 st3v3 Super Spammer
| Ariel Badger |
| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 23:05 - 08 Apr 2007 Post subject: |
They are reliable as long as you keep with the service schedule. They generally don't tolerate abuse as well as 4-strokes do, though.
Not warming them up is a sure fire way to kill them too, but when they do blow up, it costs feck all to rectify compared to a 4-stroke. If a 2-stroke seizes, you need a barrel re-plate, new piston, rings and gaskets. If a 4-stroke does it, you may need valves and timing mechanisms, too. then there's the added labour of timing it all up again.
As for not doing a 100 mile trip, i did a 280 mile round trip up round delivs bridge and god knows where and my Cagiva YES, CAGIVA didn't miss a beat the whole way.
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
| Ariel Badger |
| Pte1643 |
 Pte1643 Nearly there...
 Posted: 23:36 - 08 Apr 2007 Post subject: |
Owned an RGV for 2 yrs, way back when.
Done 30 miles a day, work and back, (Yes, I used it as a commuter ), everyday in all weathers (didn't have a car then).
She NEVER once missed a beat.  |
| JakeyR |
| bish777 |
 bish777 World Chat Champion
| MementoMori |
 MementoMori World Chat Champion
| Diggs |
 Diggs World Chat Champion
 Posted: 08:53 - 09 Apr 2007 Post subject: |
I rode my AP50 from Wakefield to Ipswich one dark, cold, long lonely night as a teenager and it didn't miss a beat. Only problem was I had to wait till 8 in the morning for petrol halfway down. 6 hours in the dark by the side of a road in the Fens is no fun...
Two strokes can be reliable if you remember to top up the oil and you clean the plugs every 500 miles of so, plus decoke and get handy with the circlip pliers.... They just need more maintenance, thats all!
I stripped the plug threads on my AP50 too... the 'bang!' it made when I tried to pull onto a roundabout and the plug hit the underside of the frame was quite impressive! Well, it impressed me... lol ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting... |
The last post was made 19 years, 7 days ago. Instead of replying here, would creating a new thread be more useful? |
