yet more help needed by me
thegubner
PostPosted: 20:03 - 09 Apr 2007    Post subject: yet more help needed by me Reply with quote
after identifying that GPZ 750 engine Embarassed , im trying to get the starter motor out, I have the cover off but there is a casing that needs to come off too, its under the carbs and down the left side.
It is held in by alan key bolts, but I snapped my alan key in them the're that tight. I got a new alan key sorted and they are just TOO tight, will NOT come undone at all, rather than coming undone they are starting to round off, any ideas?
cheers in advance (yet again)
andy
mattgirv
PostPosted: 20:33 - 09 Apr 2007    Post subject: Reply with quote
It'd be better having something gradual to apply pressure to the hex key to turn it.
If you have something longish you can fit over the end of the key to get more leverage on it then that would be good. If not perhaps try your foot gradually increasing the pressure against it.
Also spraying a bit of lubricant wouldn't go amiss, if you haven't already Wink
thegubner
PostPosted: 20:35 - 09 Apr 2007    Post subject: Reply with quote
cheers pal, i should have mentioned that I have tried those things allready, but to no avail
cheers
andy
mattgirv
PostPosted: 20:42 - 09 Apr 2007    Post subject: Reply with quote
I guess you could try heating it up with something, if you have a blow torch or something.
Also perhaps try getting a flathead screwdriver and hitting it at an angle to the hex key bolt to see if it shocks it out. Should work to a similar degree as an impact driver does.
Finglonga
PostPosted: 20:52 - 09 Apr 2007    Post subject: Reply with quote
Allen keys are not any good for that, you need an allen socket.
Like....https://www.porsche964.co.uk/technical/images/jc/10mmallnsckt.JPG
Andy Sez....
F.Y.Y.F.F.
thegubner
PostPosted: 21:08 - 09 Apr 2007    Post subject: Reply with quote
ooooo, oooo, ooo, thats what i need, oooo, oooo
i gotta get one, cheeeeeers Thumbs Up Thumbs Up Thumbs Up
although thinking about it i did make one from the snapped key and an imperial socket, but it just started to round them off, so now I think some more, no point buying em as it wont work
cheers anyway
edd
PostPosted: 01:16 - 10 Apr 2007    Post subject: Reply with quote
As Finglonga says allen sockets are your friend. What wont budge with allen keys at all often comes out with little effort using sockets. Thumbs Up
Bluespark Automotive - Diesel Tuning for Performance and Economy
steveh
PostPosted: 08:28 - 10 Apr 2007    Post subject: Reply with quote
If they were steel you could tack weld somthing on to lever it off.
Or try an inmpact driver.
if its rounded off, perhaps cut a T in it to make it take a flat blade.
Or drill it out Sick
Ichy
PostPosted: 09:57 - 10 Apr 2007    Post subject: Reply with quote
Impact driver is the way to go. If the allen key is starting to spin then you could try tapping a star drive bit in the bolt. If you know someone with a welder you could try welding a old socket onto the bolt.
Chances are the bolts going to snap if its that tight, try letting it soak in plus gas or heating up to casing.
thegubner
PostPosted: 13:41 - 10 Apr 2007    Post subject: Reply with quote
Thats for the replies, but BCF member grav, has bought the lot off me now, so its up to him, he he
The last post was made 19 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 63.7 Kb
