| Andy C |
 Andy C Tree Seeking Missile
| -Savage- |
 -Savage- World Chat Champion
 Posted: 09:47 - 07 Apr 2007 Post subject: |
put some thisk masking tape on the fairing so you can pencil in where to drill, and it also helps stop the drill bit slipping. any old bit should do, ive used metal bits when ive drilled, easy as pie. only thing to look out for, is if your drilling while the fairing is on the bike, be carefull not to drill through any hoses or anything on the other side lol ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
Peugeot Speedfight 100, Kymco Hipster 125, GSXR750K5, Jawa TS 350 |
 Posted: 09:52 - 07 Apr 2007 Post subject: |
Sitck some PVC tape over the area you want to drill. This stops you lifting the paint and lets you position the drill accurately.
Drill a small pilot hole (maybe 3 or 4mm diameter) in the dead centre of where you want to be. "Measure twice, cut once."
Fairing plastic is odd stuff to drill. You want to drill VERY slowly and don't put much pressure on the drill. If anything, you need to hold it back a bit or it bites in without actually making the hole round.
For something that size, you would probably be better using a hole saw rather than a big twist drill after you've made your pilot hole, this will do a neat and tidy job.
I'd also drill from the outside to the inside, you can trim any bits of swarf off the inside with a stanley knife
My personal preference is to use a hand drill for these type of jobs rather than an electric one. If you do use an electric it should be a variable speed one and as slow as you can make it.
If you want it to look really professional, drill the hole oversize and fit a rubber grommet in the hole, the hole itself doesn't need to be too tidy if you do that. You can buy grommets in different sizes or strips of meterial that you cut to shape and glue into a circle with superglue. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ste |
 Ste Not Work Safe
| Street Fighter |
 Street Fighter Derestricted Danger
| Kara |
 Kara Crazy Courier
 Posted: 14:23 - 07 Apr 2007 Post subject: |
Normally I'd try anything myself at least once (when it comes to bikes) but i'm paying honda to fit my bungs, they may have more luck getting replacements if they fuck em up! ____________________ NC30 + Bandit 6
www.eabikers.co.uk |
| Andy C |
 ..... Quote Me Happy
| Cillit-BANG |
 Cillit-BANG World Chat Champion
| Andy C |
The last post was made 18 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
