Bouncy front end going round corners?
-Savage-
PostPosted: 12:14 - 12 Apr 2007    Post subject: Bouncy front end going round corners? Reply with quote
when i go roind a corner leaning in, the front end can get a bit bouncy, to the extent that im scared of binning her. i presume this is due to the setting on the forks, do they need to be harder or softer?
willi
PostPosted: 12:19 - 12 Apr 2007    Post subject: Reply with quote
you may need oil in them? wat sort of bike is it?
wat goes around comes around.
veeeffarr
PostPosted: 12:21 - 12 Apr 2007    Post subject: Reply with quote
What weight fork oil do you have in there?
Diggs
PostPosted: 12:33 - 12 Apr 2007    Post subject: Reply with quote
A proper fitting bra should do it...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
CRAZY_BIKER
Guest
PostPosted: 12:47 - 12 Apr 2007    Post subject: Reply with quote
Just a thought , have you got to much/not enough air in the tires ?
Because it could well cause theses effects to the handling and response of you're bike.
Marci
PostPosted: 15:34 - 12 Apr 2007    Post subject: Reply with quote
Sounds like it needs less preload... you got adjusters?
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
feef
Energiser Bunny
PostPosted: 15:44 - 12 Apr 2007    Post subject: Reply with quote
no way of knowing if it's just preload...
a 'bouncy front end' is such a generic description, it Could be caused equally by preload, rebound or compression damping settings.
not enough damping, and it'll pogo.
too much damping, and it'll bounce because it's rock hard
too little rebound damping, and it'll top out the forks witha clunk and be bouncy
too much rebound, and it can pack down, so there's no travel left and bounce
too much compession, and it won't compress enough, be too firm, and so bounce
too little compression damping and it'll dive too easily, so bounce back up
All depends on the kind of forks, the level of adjustability and what causes the bouncing, also what kind of bouncing it is.
Is it a wallowy bounce? a springy bounce? Are there any noises, knocking coming from the fork?
before identifying ANY suspension issues, tho.. make sure your tyres are in good shape.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
PostPosted: 15:58 - 12 Apr 2007    Post subject: Reply with quote
I've seen people describe 'front end bouncy around corners' When their rear shock is shagged too.
feef
Energiser Bunny
PostPosted: 16:05 - 12 Apr 2007    Post subject: Reply with quote
quite true..
I just could't be bothered including all the Other things that can cause it, cos I'm fed up at work, and feeling lazy Very Happy
a
FreshAL
Sir Crashalot
PostPosted: 16:48 - 12 Apr 2007    Post subject: Reply with quote
I was complaining about front end wobble until I did some advanced training.
Turns out I was dealing with corners all wrong. I now sit slightly further back in the seat, and apply more positive throttle through the bend.
Front end feels so much more planted and secure it's amazing.
How old is the bike & how many miles has it done?
PostPosted: 17:05 - 12 Apr 2007    Post subject: Reply with quote
Weight over the front, but not sitting at the front of the seat, and mimimum amount of throttle should be a bit more than "Maintenance throttle".
Makes a hell of a difference! Smile
-Savage-
PostPosted: 12:19 - 13 Apr 2007    Post subject: Reply with quote
wow what a load of responses while i was away!
bikes a 99 cbr600 standard forks, dont have any idea what oil is in them, probably what was put in in the factory. its done about 27.5k miles.
im going to take it to the garage and check tyre pressures.
the bounce is spnogey/springy. theres no noise and the forks dont stop moving, they just sort of bounce lol
feef
Energiser Bunny
PostPosted: 12:20 - 13 Apr 2007    Post subject: Reply with quote
after 27k miles I'd look at flushing and replacing the fork oil.. maybe even checking the rear shock.
a
FreshAL
Sir Crashalot
PostPosted: 12:39 - 13 Apr 2007    Post subject: Reply with quote
a
Is it worth increasing the pre-load (& damping if poss.) on the rear?
I still don't completely understand suspension, so this might be a completely rubbish idea.
feef
Energiser Bunny
PostPosted: 12:53 - 13 Apr 2007    Post subject: Reply with quote
FreshAL wrote:
a
preload will stiffen the spring, and make the suspension harder. That won't necessarily fix the bounciness, it might just change HOW it bouncies (rather than wallowing/boingy, it may become hard and harsh)
Also, if the rear is harder, then any upward force on the rear wheel will cause a downward force on the front forks, pivoting about the center of gravity.
There's no real way to 'tune' out the symptoms or effects of poor fork oil, or a knackered rear shock.
best to either ride around it carefully, being aware of the limitations, until it becomes unrideable, or just get it fixed.
Suspension, steering and brakes are the 3 things I don't allow to be less than 100%. I can handle an engine that's down on power, but I still want to be able to stop and go round corners safely.
a
PostPosted: 13:59 - 13 Apr 2007    Post subject: Reply with quote
Technically it doesn't stiffen the spring, it just increases the amount of weight/force it takes to make the spring start to move. Once its moving the stiffness remains the same whether on max or min preload.
But, for all intents and purposes... Wink
feef
Energiser Bunny
PostPosted: 14:19 - 13 Apr 2007    Post subject: Reply with quote
Ohh.. pedantic Very Happy
I was trying to keep it simple for someone that obviously doens't know the technical detail of spring-rates..
The force required to compress a metal coil spring increases (in general) linearly with it's compression. Therefore, by compressing the spring with a preload adjuster, you ARE making a stiffer spring, but also making one with less travel.
Razz
a
FreshAL
Sir Crashalot
PostPosted: 14:28 - 13 Apr 2007    Post subject: Reply with quote
Razz
a
Keep it coming, I'm learning here... Laughing
PostPosted: 16:39 - 13 Apr 2007    Post subject: Reply with quote
Best thing to do is have the forks apart clean all the gunge and old watery-oil out fit new seals and re-fill with fresh oil.
Then start thinking about making adjustments.
feef
Energiser Bunny
PostPosted: 17:18 - 13 Apr 2007    Post subject: Reply with quote
This is a good place for info on suspension and how it works..
also has pages with recommended setups for various bikes.
https://www.sportrider.com/tech/suspension/
a
The last post was made 19 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 118.87 Kb
